Old 06-10-2008, 11:19 PM   #1
gerudas11
gerudas11's Avatar
gerudas11 is on a distinguished road
Belts Question
So I pulled the ac and the belt. I pulled the belt off of the power steering because the steering rack was leaking. I still have the air pump on but I was thinking about removing that as well... will there be any issues? Will I need the dual pulley?
gerudas11 is offline   Reply With Quote
Old 06-12-2008, 09:07 AM   #2
well uhhh
well uhhh is on a distinguished road
uhh, if you still have the stock cats then no, you cant remove the airpump unless you wanna burn up your main cat. if you have emissions removed, then you either want to put a dual pulley on or get a yoohoo belt like the one pinapple sells.
well uhhh is offline   Reply With Quote
Old 06-12-2008, 09:14 AM   #3
gerudas11
gerudas11's Avatar
I have an aftermarket exhaust so I would be fine with taking off the airpump.
