Old 06-04-2008, 08:06 PM   #1
Rotary_Rocket_87
2nd Generation Freak
Rotary_Rocket_87's Avatar
Rotary_Rocket_87 is on a distinguished road
motor differences
I have been searching for a while on this one. Every thread that I have read that mentions the differences of S4 and S5 engines only state that the intakes are different and if it has EGR it is S4. The only thing I have found to help determine which series a shortblock is that the spark plugs aren't located the same on S4 and S5 rotor housings. Mazda moved them on the S5, but I can't find an info on how they moved them (measurements). Does anyone have anything else?
'87 TII- full emissions removal, a/c removed, FPD removed, dual 12" e-fans, Rotary Performance FCD, ACT unsprung 6 puck w/ Xtreme PP, custom open 2.5 inch exhaust, custom clutch pivot ball, K&N cone filter, TB mod, RB downpipe, motor blown 8/7/09
'94 Mazda B4000- POS beater truck, stock
"The easiest way to fail is to never try." - Me
Rotary_Rocket_87 is offline   Reply With Quote
Old 06-04-2008, 09:03 PM   #2
TehMonkay
Coolant temp sensor is different, has a bannana plug on S4 and spade on S5, also there is an indentation in the front cover for the S5 waterpump.
The clutch fan has more blades on the S5, I think 8 S4 10 S5.
If the injectors are on it, S4 has square top injectors, with EV-1 connectors, S5 has more of a rounded shape to the connector.
Old 06-04-2008, 10:31 PM   #3
http://fc3spro.com/TECH/FAQ/ZVK/zvk.html
Old 06-05-2008, 06:48 AM   #4
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
Nice link.
Rotary Rocket did mention a "short block"
N/A or Turbo though?
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
Old 06-05-2008, 09:30 PM   #5
Rotary_Rocket_87
I have just been trying to figure out if the motor has been replaced in my T2. I already knew how to tell motors apart by the bolt on stuff, but didn't know about the block parts. Thanks for the great link Ted.
