Old 05-28-2008, 07:58 PM   #1
-xlr8planet-
-xlr8planet-'s Avatar
THIS is going inside my FB...
Old 05-28-2008, 08:13 PM   #2
PercentSevenC
Custom User Title
PercentSevenC's Avatar
Cool. I'm very interested in seeing the results.
Old 05-28-2008, 08:44 PM   #3
-xlr8planet-
I stole the idea from this australian
Old 05-28-2008, 09:20 PM   #4
-xlr8planet-
mo picsssss
Old 05-28-2008, 09:26 PM   #5
-xlr8planet-
Last ones
The back of the A/C panel does not let me put everything in place.
I will remove some stuff this weekend
Old 05-28-2008, 09:32 PM   #6
PercentSevenC
Custom User Title
Are you going to do something with the door skins as well? That Australian one looks a little odd... modern dash with old-school door skins.
Old 05-28-2008, 09:44 PM   #7
-xlr8planet-
I will make them from scratch
foam and fiberglass, then upholstery
Old 06-05-2008, 06:58 PM   #8
warwickben
sa rat rod
you need to go step by step with this please. my buddy is doing a rhd swap on his fd and is willing to give me the parts needed.
i would most likely use the cluster area only then build the rest , they way you have it mocked up now, do you have any problem seeing where the gauges will be.
also as a side note. how do i get a mph gauge to work with a sa tranny
Old 06-05-2008, 08:17 PM   #9
-xlr8planet-
To get the FD cluster to work you need to "feed" it with the correct inputs. I´ve been over the diagrams and some FB sensors can made to work, while others need to be replaced (oil press for example).
To get the speedometer to work, you have to make one piece out of the tranny output of the FB (mech) and the on of the FD (speed sensor) Then you send out the dash to get re-calibrated.
Everything seems to fit. No cutting needed
Old 06-06-2008, 04:54 AM   #10
warwickben
sa rat rod
i havnt looked at a fd cluster in a long time could i use it to hold after market gauges.
Old 06-06-2008, 10:55 AM   #11
-xlr8planet-
Yeap. Just need to cover
They would fit
Old 06-16-2008, 12:57 PM   #12
Nutsid
Temporarily insane.
Nutsid's Avatar
Once you do the door skins, that should be one insane interior. I like the way the FD's interior was setup (even if quite a lot of it was cheaply made). It should definitely look good inside the FB so long as the rest of the interior is modernized as well. I can't wait to see the finished product.
Kindle
Nook
Old 06-29-2008, 10:00 AM   #13
warwickben
sa rat rod
any news
Old 06-29-2008, 12:22 PM   #14
-xlr8planet-
I´ve been waiting for a dashboard
