Old 05-27-2008, 02:29 AM   #1
FC Zach
FC Zach's Avatar
Problem w/ Parking lamps
The harness going to the light switch has one burned wire along with a burned pin in the switch. Is it the harness or the switch that is causing this problem? I think its a bad connection thats causing this but not completly sure. Ive had this problem before on my other 2nd gen so this must be common problem. There are other threads on this but no updates on what the problem was and how it was fixed, any info would be greatly appreciated.
Old 05-27-2008, 08:50 AM   #2
TehMonkay
Replace the harness and switch, and relay your headlights.
I've never had these headlight issues, i guess im just lucky.
Old 05-28-2008, 03:09 AM   #3
FC Zach
FC Zach's Avatar
I replaced the H/L switch and so far everything is working fine, I would have replaced the harness too but didnt have an extra one laying around. Is the relay necessary? The head lights work fine, its just the driving lights im worried about.
Old 06-01-2008, 10:31 PM   #4
FC Zach
FC Zach's Avatar
I was given a harness to try, so far so good. The culprit must have just been a bad connection between the two.
Old 06-03-2008, 11:34 AM   #5
Warui Shujin
Warui Shujin's Avatar
Warui Shujin is on a distinguished road
When mine did that, I just cleaned the connection and stuck it back together. somewhat melted, but it works.
Warui Shujin is offline   Reply With Quote
