Old 05-26-2008, 08:14 PM   #1
P71
P71's Avatar
My FB is now on E85!
I ran the first 3 gallons of E85 through the FB. It's 85% ethanol (corn around here) and 15% gas for "104" Octane (the RON is 114 though). After tons of reading about E85 and it's effects (alcohol eats rubber, need 20% more E85 for the same amount of gas, etc) I decided to run a few gallons through to "see what happened".
Observations:
* Cold start up was easier. It is a 230K mile 12A but it "caught" quicker and generally seemed happier. Hot start up was much improved.
* Performance (by the seat-of-my-pants) seemed better. Not loads better, but there was definite improvement. Maybe even just smoother?
* Mileage does drop. Granted 3 gallons around town wailing on it is pretty lousy anyways, but expect to see a 15-20% drop in mileage.
* Tip-in was worse. (The reaction of the engine/carb as you first touch the throttle). It's always had a "slight" hesitation from idle, the E85 made it more pronounced. Re-jetting of the carb all the way around (and honestly probably a rebuild too) needs to happen.
* Cooling was improved. My RX-7 has never run "hot" anyways, but there was a marked improvement in keeping the temp down cruising around. Cooler fuel = cooler engine.
So is it worth it? I don't know yet. With the decreased fuel mileage the cost savings isn't there. The hot-start and cooling benefits are worth it if I can cure the tip-in, I will admit. E85 is well proven on boosted applications, but the N/A 12A doesn't "need" the 104 Octane (though carbon buildup, etc might play into mine). For now I'm going back to regular 87, but if I ever rebuild the carb or swap another one (or go boosted) I think I'll be back.
Michael Pinto
Read my Rx-7 Build Thread!
Vote for the ROTM!
P71 is offline   Reply With Quote
Old 05-27-2008, 12:26 PM   #2
Kentetsu
Kentetsu's Avatar
Interesting. How did you address the possibility of the alcohol eating the rubber gas lines?
Old 05-27-2008, 11:27 PM   #3
Jeff20B
Jeff20B's Avatar
Do Sterling's accel pump mod and swap in larger primary fuel jets (stock are 92) so count on 95, 100 or 105 since those sizes are easily purchased. I have those sizes and can do the AP mod... should I try E85 on my next 12A?
Old 05-28-2008, 12:02 AM   #4
P71
P71's Avatar
Go with the 105's and yes, try it.
I used additives for the rubber as I wasn't planning on "long term exposure". New alcohol-resistant rubber/silicone fuel hose is required for permanent usage.
Michael Pinto
Vote for the ROTM!
Old 05-28-2008, 06:06 PM   #5
PercentSevenC
Custom User Title
PercentSevenC's Avatar
I'm more concerned about the effects on the carb body and intake manifold, etc.
E85 would be fun to play with on my blow-through setup once I finish it. If we ever get a station around here, that is.
