Old 05-16-2008, 03:51 PM   #1
AHarada
What rear counterweight should I be using with a 9lb centerforce flywheel?
Just as the title states. When I bought my car, the previous owner said he had a SR motorsports lightweight flywheel installed. Guess he was wrong because it clearly says centerforce. I just weighted it and it is 9lbs. The rear counterweight I took off has sharpie writing on it that says "S5 AT CWT". Does this seem like the appropriate part to use?
Old 05-16-2008, 03:54 PM   #2
AHarada
Looking at the centerforce website and searching the club, it seems like centerforce doesn't even make a lightweight flywheel for the 3rd gen. Now I'm confused.
http://www.centerforce.com/clutches....&flymake=MAZDA
Old 05-16-2008, 03:59 PM   #3
TehMonkay
You have the right counterweight, you can bolt any aftermarket flywheel to it.
Old 05-19-2008, 11:36 AM   #4
Proxy One
Victory Is Mine
Proxy One's Avatar
Proxy One is on a distinguished road
To my knowledge all light weight flywheels use the Auto transmission counterweight of the same year.
www.dealsgaprotaryrally.com
1994 Rx7 White 2001 RZ GT35R'd
1972 Rx2 Orange Coupe 5spd
2006 STi
1986 Buick GN
Proxy One is offline   Reply With Quote
Old 05-21-2008, 09:18 AM   #5
Its possible that previous owner might of bought the flywheel from SR.. I wouldn't worry about the flywheel as long as the condition is ok. You might want to go get it re surfaced while its out though.
Old 05-21-2008, 09:03 PM   #6
AHarada
Thanks guys.
It does look like it could use a resurfacing. There are some grooves and some discoloration. Where could I get this kind of work done?
Old 05-23-2008, 12:36 PM   #7
McVicker
McVicker's Avatar
McVicker is on a distinguished road
any competent machine shop should be able to do it for you.
Scrubs McBubs!
SakeBomb garage.com
McVicker is offline   Reply With Quote
