Old 05-07-2008, 10:32 PM   #1
Eatmyclutch
business as usual
Eatmyclutch's Avatar
Eatmyclutch is an unknown quantity at this point
High beams randomly turn on/off when headlights are turned on.
How do I fix this? Is there some kind of hi-beam fuse?
Bitch
Eatmyclutch is offline   Reply With Quote
Old 05-08-2008, 10:40 AM   #2
Kentetsu
Kentetsu's Avatar
Probably caused by buildup inside the switch. Get a can of "electrical cleaner" from Autozone, and hose down the area at the base of the stalk.
Check this thread out, but you probably can get away without disassembling everything. Just stick the hose into the right area and spray away, then work the switch back and forth for a bit.
http://www.rx7club.com/showthread.ph...dlight+cleaner
