Old 05-03-2008, 12:54 PM   #1
TRISPEEDFD3S
TRISPEEDFD3S's Avatar
TRISPEEDFD3S is on a distinguished road
Question Transmission/Clutch Related (Need Help)
Alright here goes...
I have an Exedy Hyper Single clutch kit, on a rebuilt transmission with about 30K on it right now. The clutch fork has never been replaced though, and it should have 87 k on that, my master cylinder has never been replaced 87 k on that, but the slave has been replaced 20 k on that, throw out bearing, pilot bearing etc...
Now that I've told you what I have, here is my problem:
My clutch slips and makes a slipping rubbing noise (sounds like a slipping belt) when I give it a little more gas than needed in 1st and reverse. It doesn't do it in any other gear. It will slip then catch and let you go on your merry way. Sometimes it doesn't do it though, usually when I'm driving like a granny or sometimes it just won't do it. I've had my mechanic replace the pilot bearing, throw out bearing, rear main seal, and the o-ring behind the stationary gear, and it solved the problem for about a week, and it started doing it again. He showed me the old pilot bearing and he was curious why it was so gritty like sand.
I'm not sure what the problem could be, but I want to figure it out since my motor went because of coolant seals, and I'm in the position to swap out motors, I want to take action on this transmission problem while she's down. Could it be my clutch? Clutch Fork? etc.... I hope someone whos been through this could help me out. Thanks in advance.
-Jeff
My Cardomain!
http://www.cardomain.com/ride/2179693
TRISPEEDFD3S is offline   Reply With Quote
Old 05-04-2008, 03:42 PM   #2
TRISPEEDFD3S
Talked to a buddy of mine, and it's probably just oil getting in there...
My Cardomain!
Old 05-07-2008, 02:39 PM   #3
I would take the clutch apart and and see if you see any residue on the pressure plate. If it was your o ring or main seal, then oil could get in and cause this issue.. But you should be able to still see some oil residue or build up.
Old 05-08-2008, 10:15 AM   #4
IR Performance
If you are getting oil on the clutch is is most likely from the rear main seal. An easy way to look is to pop off the access cover on the bottom of the trans and see if it is leaking down the rear iron.
Old 05-09-2008, 04:11 PM   #5
TRISPEEDFD3S
Yeah it WAS the rear and the o-ring. had them replaced, and probably what was happening was exactly what Phil said. When I pull my motor out I'll clean it up. What should I use to clean it all up? My buddy said gasoline.
My Cardomain!
