Old 05-02-2008, 04:36 PM   #1
sumdeus
sumdeus's Avatar
sumdeus is on a distinguished road
Mazdaspeed intake
So I figured I would give my hand a shot at modifying my '07 RX-8 and as my first time modifying my car I decided to start with something simple so I chose the Mazdaspeed intake. Installation went fine, did run into any major and the car runs just fine. It sounds better and looks better than another anonymous black box under the hood.
One thing though; there is a second set of wires on the MAF sensor harness that were attached the the vacuum solenoid, is there anything I should do with those wires?
The wires I am taking about are pictured below sitting on the cover of the fuse box.
Second thing, what does the filter sock provided do?
sumdeus is offline   Reply With Quote
Old 05-02-2008, 10:35 PM   #2
Not sure what the deal is with the left over connector... I'd expect anything factory to be well.. factory and to use all the plugs, so I can't help there.
The filter sock though is something I've never used on the car, but JEEP guys use them to basically "prefilter" the air and keep the element cleaner when going into some really nasty areas. Not sure if its really needed on a street driven car though..
Old 05-03-2008, 12:03 AM   #3
I8U
KONI Challenge Crew
I8U's Avatar
I8U is on a distinguished road
That connector originally went to the VFAD since, it is not used with any aftermarket intake...you either just hide the connector somewhere or do as I did and cut the connector off, heat shrink the the wire ends and re-tape back down to the original wire bundle. I haven't had any fault codes come up and I have been running it like this for about 3 months.
04 TiGray RX8 MT, LS2 coil setup, 3" midpipe, HKS Hi-power 3" exhaust, TEIN S-Techs, Hotchkis Adj F/R sways, K&N Typhoon V2, Steel braided brake lines, Redline drivetrain fluids, ATE Super Blue brake fluid, Cobalt XR2/GTS brake combo, MB Motorpsorts Weapons 18x9 +45 offset, 275/35's
I8U is offline   Reply With Quote
Old 12-21-2011, 09:52 PM   #4
jimstaz
jimstaz's Avatar
jimstaz is on a distinguished road
with you intake did you feel any power gains with your mazdaspeed intake? better throttle response and stuff like that? didnt mazda discontinue it? i thought they did but for what reason? give me a history lesson if asnyone knows?
jimstaz is offline   Reply With Quote
Old 12-22-2011, 05:38 AM   #5
Sephitrask
BOILED PEANUTS!!!
Sephitrask's Avatar
Sephitrask is on a distinguished road
As mentioned above, that clip is for the VFAD system. Very important question; did you put a vacuum cap on the intake manifold were the vacuum hoses for the vfad were? If not you need to....
www.rotarycarclub.com
"The way a Rotary engine makes power is ferocious, much like having a chainsaw under your right foot."
Sephitrask is offline   Reply With Quote
Old 12-25-2011, 04:11 PM   #6
jimstaz
jimstaz's Avatar
i think im gonna go with the K&N typoon intake V2.. ive seen more positives with it then negatives.. any feelings on this? some one said its also a "repackage AEM" what does that mean?
