Old 04-29-2008, 01:53 PM   #1
P71
P71's Avatar
Exclamation SA/FB/Old School/4x110 guys help!
I want to put a set of 15x8" wheels on my rx-7, they have a +15 offset. What's the stock offset on a GSL? I need to know so I can order up the correct spacers!
Michael Pinto
Read my Rx-7 Build Thread!
Vote for the ROTM!
P71 is offline   Reply With Quote
Old 04-29-2008, 03:17 PM   #2
P71
P71's Avatar
+38mm offset on the stock "+" wheels. I just went and measured my damn self :P
Michael Pinto
Vote for the ROTM!
Old 04-29-2008, 08:53 PM   #3
Unless you are going with flares, I don't think they will fit without sticking out.
Old 04-29-2008, 09:38 PM   #4
P71
P71's Avatar
Oh yes, yes they will. Read my findings:
http://www.rotarycarclub.com/showthread.php?t=2031
Michael Pinto
Vote for the ROTM!
Old 04-29-2008, 09:49 PM   #5
But won't it stick outta the fenders?
Old 04-29-2008, 09:54 PM   #6
I mean...the stockers stick out only .8" from the hub according to your numbers.
The 15x8s will stick out 2.9" according to your number. An extra 2" inches seems like alot. Plus the adapter is .375" so you have approx. 2.375" of extra width.
Maybe I am just missing something, thats why I ask
Old 04-29-2008, 10:17 PM   #7
-xlr8planet-
-xlr8planet-'s Avatar
I used 16x8 in the back.
havent tried that size on the front, but looks like it will stick out...
Old 04-29-2008, 10:27 PM   #8
^What offset?
Old 04-29-2008, 10:43 PM   #9
P71
P71's Avatar
Re-do your math, you're mixing positives and negatives, I think?
While the 15x8" is 2.5" wider of a wheel, the whole "package" is only 20mm wider, or about 3/4". The 185's "balloon" off of the stock wheels while the 205's and the 8" wheels are the same width.
Look at it like this, the tread width and section width of the tire are the only things to worry about as that's what gets close to the fender lip. The stock 185 tire has a 185mm tread width (give or take, each tire brand/model will be different) which is 7.3". The 205 tire has a tread width of 205mm which is 8". So even with making the backspacing/offset equal, the increase in overall width is only .7" or about 18mm. That's less then 2cm and less then 1". There's a good 1.5" in between where the tire would be and my fender lip. The only real difference is where the wheel itself is in relation to the body, and with most +15 15x8 wheels you will end up with a deep lip so it's only the actual "rim" that will be out the additional amount, and there's plenty of room to grow in that area from the "+" wheel!
I attached some pictures
Michael Pinto
Vote for the ROTM!
Old 04-29-2008, 10:44 PM   #10
-xlr8planet-
+25 offset
Old 04-29-2008, 10:55 PM   #11
P71
P71's Avatar
Originally Posted by -xlr8planet- View Post
+25 offset
Spacers? What size tire? Will it clear the front strut and fender?
Michael Pinto
Vote for the ROTM!
Old 04-29-2008, 11:19 PM   #12
-xlr8planet-
no spacers.
108x4 bolt pattern
I never tried them in the front. I was just "testing" them
Old 04-29-2008, 11:21 PM   #13
P71
P71's Avatar
Hopefully you used the "wobbly" lugs...
Without a spacer the outside face is dead even with stock and the inside is 20mm closer to the strut/suspension.
Michael Pinto
Vote for the ROTM!
Old 04-29-2008, 11:26 PM   #14
I guess your tire selection will make it work. I guess I was a little confused because most people upgrading to a 8" wheel do so to gain greater width than they can run stock. I am running 215" on stock 5.5" GSL-SE wheels.
Old 04-30-2008, 12:47 AM   #15
P71
P71's Avatar
205/50/15 is the super-awesome autocross/road race tire size for Miata's and Civic's. So I can get Falken Azenis Rt-615's (basically the closest you can get to an R-Compound without being an R-Compound) for $72 each. Why go to a 215 or a staggered setup when those class of tires in a 205 is more grip then the 12A can even handle? A 205 is still an 11% increase over a 185 on contact patch!
Remember, for hard cornering you want the widest rim you can get the tire to fit on with out "stretching" to have a nice 90* sidewall with no balloon. A 15x8" wheel with a 205 tire is a perfect match for that. And again, the whole $$$ comes into play. If I had serious cash I'd do an FC 5-lug brake conversion and go from there, but sticking with a cheaper class limits me to stock size/style rotors (but they can be slotted/better made) and to whatever I can get to stay on there.
Michael Pinto
Vote for the ROTM!
