Old 11-15-2018, 01:28 AM   #1
Kinugawa FC3S turbo oil feed line
I was kinda forced to get this, because I just could not get the stock turbo oil feed flange to seal on top of the turbo.
Oil leaking from here drips down the center housing and gets on the turbo exhaust manifold, which then burns and smokes...
Even after multiple attempts with the stock Mazda gasket, I looked for an alternative...
The Kinugawa unit looked good.
But...
* The line is 6" too long - I ended up looping the end that goes into the banjo bolt.
* THIS IS THE BIG ONE: the new banjo bolt does not fit on my 1987 model - the threads were the wrong pitch!
They are advertised for "86-91" models, but be warned!
Luckily, I could reuse the old, original banjo bolt
Make sure you use the new crush washers, which are wider than stock - I.D. is same as stock but O.D. is wider.
Using the stock skinnier crush washers induced a very large oil slick under the car.
The kit comes with a (cheapie) paper gasket for use between turbo and flange, and it works okay.
Old 11-15-2018, 05:15 AM   #2
FC Zach
FC Zach's Avatar
For a just-in-case backup, I bought the turbo coolant inlet/outlet flange and hose assembly for my Celica off ebay from that brand. The lines were WAY too long in my kit too.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 11-15-2018, 09:55 AM   #3
Interesting, I've never had a problem getting that stock flange joint to seal up properly, never had a leak there. Perhaps your flange or turbo mating surface was warped or misaligned somehow?
I just use the factory paper/fiber gasket, with a very thin & even skin coat of blue Hylomar on both sides of the gasket & torque bolts to FSM spec. My current BNR turbo setup needed an oil pressure restrictor to prevent smoking, so I fabricated an 0.096" thick AL restrictor plate and sandwiched it between the oil feed pipe flange & turbo with gaskets on all mating surfaces. Needed slightly longer bolts, but it still doesn't leak, which shocked the hell out of me.
Old 11-18-2018, 05:12 AM   #4
I think all the removal and reinstallations warped the stock flange for me.
I tried to sand down the flange and found that only the outside edge of the flange showed scuff marks - the center hole + good 2mm around it was untouched by the sandpaper.
A unique advantage of this system is that you can easily remove the flex hose with a 14mm wrench and move it out of the way.
With the stock hard pipe, you kinda have to bend it slightly to get the turbo out.
