Old 04-21-2008, 12:36 PM   #1
Boostmaniac
REV TII exhaust.
I am looking for the best place to buy a complete Racing Beat REV TII exhaust. I am getting conflicting information on prices and even specs across multiple sites. Any info would be greatly appreciated.
Also, does anyone have a factory S5 shifter laying around they would be willing to part with?
Thanks again!
-Maniac
Old 04-21-2008, 02:42 PM   #2
go through the site that makes the exhaust. www.Racingbeat.com
What are you looking for specifically?
Old 04-21-2008, 03:06 PM   #3
Boostmaniac
The entire exhaust system, Downpipe to Mufflers. I was just curious because RX7 store had it listed cheaper, but with slightly different specs.
It just had me slightly confused.
Old 04-21-2008, 04:03 PM   #4
make sure it's not the old one. Imma check out the info.
Old 04-21-2008, 05:12 PM   #5
$780.00
Originally Posted by rx7store
1987-91 TURBO II Complete High Performance Exhaust System*
This is the ultimate exhaust for any Turbo II RX-7! Let your turbo breathe to it’s full potential with our “turbo-back” complete exhaust system.
The Turbo II High Performance Exhaust system incorporates a 3.15-inch (80mm) down pipe from the turbo outlet that mates to a presilencer section. From the head of the Y-pipe two 2.375-inch (60mm) pipes extend to the ceramic wool-packed 304-stainless steel rear main mufflers. The bolt-on exhaust system increases horsepower approximately 32% - a 59 HP increase on a 1987 Turbo II RX-7!
$825.00
The REV TII High Performance Exhaust system incorporates a 3-inch OD down pipe from the turbo outlet that mates to a presilencer section. From the head of the Y-pipe two 2.375-inch OD (60mm) pipes extend to the ceramic wool-packed 304-stainless steel rear main mufflers. The bolt-on exhaust system increases horsepower approximately 32% - a 59 HP increase on a 1987 Turbo II RX-7!
The REV TII High Performance Exhaust system reduces exhaust gas back-pressure significantly, thereby allowing the un-assisted turbo boost pressure to increase to 10-11 psi. Our Fuel Cut Controller (part No. 11570 or 11571) is required to prevent fuel cutoff to the rear rotor above the factory pre-set limit.
This bolt-on system uses the stock mounting points for ease of installation. Each system is supplied with all necessary mounting hardware and gaskets (does not include turbo outlet gasket). The down pipe section is provided with a position for the oxygen sensor.
Old 04-21-2008, 05:23 PM   #6
$100T2
Big Daddy
$100T2's Avatar
See which one is cheaper with shipping and go with it.
Old 04-22-2008, 07:20 AM   #7
Boostmaniac
Sounds good.
Old 04-30-2008, 11:02 AM   #8
FirstRotaryExp
what it sounds like here is the RX7store just copy/pasted racingbeats site nearly word for word, Id still buy the RB setup>rx7store setup
Old 04-30-2008, 11:30 AM   #9
well uhhh
well uhhh is on a distinguished road
i noticed that the description on rx7 store is the same for all the exhaust, even the non RB ones. It sounds word for word what is on the RB site.
well uhhh is offline   Reply With Quote
Old 04-30-2008, 04:09 PM   #10
MidnightOwl
BAND. You got talent.
MidnightOwl's Avatar
MidnightOwl is on a distinguished road
If it's cheaper on Rx7store and is a Racing Beat exhaust, there isn't a problem!
88 Turbo Vert - mostly stock, S5 turbo, full exhaust, Greddy Profec B Spec II, full emissions removal
90 240sux - daily driver of DOOM.
www.daviddrinkard.com
MidnightOwl is offline   Reply With Quote
