Closed Thread
Old 08-28-2015, 11:48 PM   #1
Slides
Zero clearance side seals round 2. (If you don't mind Barry)
I genuinely though Ted forgot the italics in his comment here until I saw it was actually closed. Not sure why you wouldn't want documentation of long term runner that someone has tested in one place? (I will say mods/admin on other forums encourage keeping tech stuff in one place)
So, seems this is a goer.
I would like to do this when I eventually get around to building one or other of my engines, the 12a will have to come apart for clearance/lighten/balance anyway as there was still vibes with what was sold to me as the correct series auto counterweight (will do the measuring check etc again but I want to port it anyway, will send to spinny bits to Freaky or Wilkins to machine) with after-market flywheel and there was an issue with leaking intake crossover o-rings/gasket filling housing with coolant too so I'm guessing it could be a bit messy inside.
If you don't mind me asking Barry do you cut them with a fine diamond disk with a dremel style thing or is it more like a milling bit. I guess I'm curious as to whether there is a tight or open radius under the side seal and how hard it would be for me to replicate it, given sending you seals/rotor from Aus would be cost prohibitive and I'd like to try it myself anyway. Is there enough length in generic side seals to do this effectively?
Slides is offline
Old 08-29-2015, 07:17 AM   #2
88turboii
destroy, rebuild, repeat
88turboii's Avatar
why do you knotch only one side of the corner seal.. why not both, or are the side seals not long enough?
i agree, lets keep it in one thread
88turboii is offline
Old 08-29-2015, 07:34 AM   #3
Barry Bordes
Barry Bordes's Avatar
Slides,
The Dremel diamond disk blade #545 is made to cut on a 7.344" arc.
The frame is angle iron.
Notice the stop screw for depth and the adjustment for width. On the width adjustment 90º =.008" with a 10-32 screw thread.
The apex seal shown, is stuck in the fixture to rock the corner seal to its full travel.
Use water to extend the life of the cutter. The seal holder is made from one corner of an old rotor and tapped/screwed to the angle.
If you were closer geographically it might be worth sending them to me and I would cut them for you for free.
On second thought it would be better for you to make the tool and provide the service for others over there.
I can send you more pictures if needed.
Barry
Barry Bordes is offline
Old 08-29-2015, 08:00 AM   #4
Slides
88Turboii, it is redundant work cutting both sides of the corner seal, you only need to cut the one at the leading edge of the side seal as the rotation of the rotor against the side plate will maintain the gap tight at the trailing end, thus you only need the "labyrinth" at the leading end of the side seal to allow seal expansion without gas bypass.
Thanks for the detailed reply Barry. Perhaps just one photo from 180 degrees of the existing one so I can see how much of the rotor you have used and the way it approaches the seal.
I think I will try to put a jig together, as it happens I already have a diamond bit which looks pretty close (although I would make sure I had several of correct thickness before starting) and dremel style tool although I might not be pulling the motor for a while, I suspect I may have to make a career change to get cash flow happening (I'm hoping I don't have to sell one of the 7s in the mean time). I would certainly make any jig or tool I put together available to other rotary community members here, I have happily volunteered my time to help forums members (rotary and otherwise) with various bits and pieces before. I have learned a bit about air cooled porsche motors in the last few weeks, getting intake and head studs out isn't always fun, and they can run without head gaskets
Slides is offline
Old 08-29-2015, 08:04 AM   #5
Barry Bordes
The problem is tolerance shift. Mazda manufacturing tolerances are very good but are still off a small amount. Each side seal and corner seal is slightly different and thus must be fitted carefully to eliminate any binding.
My thought is that using one cut is half the fitting and half the possibility of binding an apex seal. I have the side seal push on the uncut flat side and the normally gapped open side is in the labyrinth cut.
An additional feature is that on final assembly build.... the apex seal to corner seal alignment is perfect... just slide them in.
That said... if you want to do both, do both.
Barry
Old 08-29-2015, 08:39 AM   #6
Barry Bordes
Wow Slides.
It is uncanny how close our thought processes are.... You just type faster!
Barry
Old 11-04-2015, 04:15 PM   #7
Barry Bordes
Slides
I PM'ed a better picture of the tool's rotor fixture set-up.
Sorry for the delay.
Barry
Old 11-05-2015, 05:08 PM   #8
RICE RACING
Don Mega
RICE RACING's Avatar
There is some real dumb and wrong assumptions state above ^
The side seal is NOT constantly forced to one side!@ IF it were it would never wear a path into BOTH corner plugs as it does in reality!
A true ZERO BLOW BY design like I have made needs to be recessed into both corner plugs and not some ghetto cut off wheel doing a straight edge cut leaving a sharp edge too! that will not only seal like total crap but cause a very large stress raiser in the corner plugs = very poor idea.
If you look at the rotor path you will see the side seal rocks back and forth in the side seal groove on each minor dimension of the rotor housing points, thus it slams from one side to the other in the side seal groove! it needs to be recessed into BOTH, so not only is the clearance NOT zero as in the un thought out claims by others who have butchered this mod, but its also not the correct way to do this either as shown above.
Here is how its done right! below. This to work properly needs a bespoke material side seal and corner seal, as the stock parts are failure prone as is.
There is clearance to all parts! and needs to be done by not an engine builder wannabe but by toolmaker/fitter/turner who have precision parts fitting qualifications and experience, NOT GOOGLED!@
ZERO BLOW BY RICE RACING
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
RICE RACING is offline
Old 11-06-2015, 09:20 AM   #9
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
t_g_farrell is offline
Old 11-06-2015, 10:10 AM   #10
FC Zach
FC Zach's Avatar
Very Pretty! !
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
FC Zach is offline
Old 03-09-2016, 11:28 AM   #11
Barry Bordes
p
[QUOTE=RICE RACING;320079]There is some real dumb and wrong assumptions state above ^
Peter you are incorrect. Anyone who has disassembled a rotary has seen that you have blow-by on only one side of the corner seal. If you see wear on both sides you have set the side seal too tight and the corner seal may fail... (along with pinching the apex seals and adding high wear to the side plates)
You had problems in that area before with NRS corner seals... maybe that was the problem.
The rotor can only go one direction... and parts of it may sweep faster or slower, but all portions are always going forward... rethink your position.
QUOTE]
GOD the Incomprehensible Obvious (www.frksj.org)
Old 03-09-2016, 12:50 PM   #12
Easy Cheeby..... technical discussions are aight
TitaniumTT is offline
Old 03-09-2016, 03:09 PM   #13
In a PERFECT environment, this is true...
You might find it surprising, and most of us live in reality...
Under less than ideal conditions, seals can resonate back and forth.
I.E. under pre-ignition and / or detonation
If you can guarantee that your engine will never see such conditions, then you would be right.
RETed is offline
Old 03-09-2016, 03:23 PM   #14
Boost vac boost vac boost vac boost vac..... see where I'm going with that?
Old 03-09-2016, 03:32 PM   #15
Can you explain even further...
RETed is offline
Closed Thread
