Old 06-29-2015, 08:39 PM   #1
87 t-66
87 t-66's Avatar
87 t-66 is on a distinguished road
fuel system/alcohol kit/EBC/greddy elbow/works bell/rear counterweight/99+ ECU/ETC.
PM me if interested...
Fuel system - KG rails, new aeromotive FPR, new autometer 3312 gauge, 2x ID725 injectors with hats, all SS lines and fittings pictured - $500
99+ ECU - $40
Works bell rapfix 2 hub and hub lock with key - $325
Apexi auto timer with FC harness - $50
HKS EVC EZ - $120
Cooling mist alcohol kit – comes with controller, pump, tank, new lines, new nozzle, new misc other fittings - $160
New? Greddy elbow w/ alcohol injector nozzle bung welded on - $100
aftermarket waterpump outlet - $25
stock waterpump outlet - $20
alternator with pulley and bracket - $80
New connectors for crank sensors, tps, 2 new square injectors pigtails - $15
New jegs through panel connectors w/ hole saw bit - $15
Stock flywheel - low miles - $40
Rear counterweight with mounting bolts - $100
87 t-66 is offline   Reply With Quote
