Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > ZN Performance
ZN Performance (OH) www.znperformance.com RX7 and RX8's performance and parts. 3488 Millikin Court Columbus Ohio 43228 614-264-9588
Old 03-09-2015, 03:49 PM   #1
zayrx7
zayrx7 is on a distinguished road
Our ligthen rotors
Here is a pic of our lighten and balance rotor going in one of a built semi-port motor
zayrx7 is offline   Reply With Quote
Old 03-09-2015, 04:07 PM   #2
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
How much weight did you remove? It looks like they were just barely "lightened" for balancing purposes..
Maybe post up data for before/after of both the lightening and balancing?
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 03-09-2015, 04:11 PM   #3
What series rotor?
Old 03-09-2015, 05:12 PM   #4
zayrx7
What series rotor?
fd rotor C
Old 03-09-2015, 05:13 PM   #5
zayrx7
there's more weight removed on the face, didn't take a pic
Old 03-09-2015, 05:27 PM   #6
zayrx7
it's about 70 thousand taken off, not that much in lower the compression, we are going to run 40 plus pound of boost on this motor with E85
Old 03-09-2015, 05:56 PM   #7
RICE RACING
Don Mega
RICE RACING's Avatar
sounds like you need the best apex seals...........
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 03-09-2015, 05:59 PM   #8
zayrx7
For sure in my next built
Old 03-10-2015, 01:53 AM   #9
chibikougan
chibikougan's Avatar
Not to be a dick or trash on you at all. Genuine concern.
Now isn't where you took all that material from going to interfere with engine operation?
Is that lowering compression? How much?
Anyone else any thoughts on that?
At dead center the chamber splits into 2 and forces the fuel air mixture through the exclusion to be ignited no? Would doing away with the exclusion ignite leading and trailing at once?
Also can it come away from the shaft like that?
Old 03-10-2015, 08:04 AM   #10
Slides
You realise the tub in a standard rotor joins the two ignition points with a far larger/better flame path than any face machining ever will right? Any difference around the sides of the tub is inconsequential in terms of flame path vs the tub itself.
Old 03-10-2015, 09:05 AM   #11
My concern is taking the weaker of the rotor series and removing material close to where they're very thin and like to dent anyway.
Old 03-10-2015, 11:59 AM   #12
zayrx7
No concerns on this method! it was done by 2 well know shops
Old 03-10-2015, 02:00 PM   #13
Ah, so it's not actually your machine work?
Old 03-10-2015, 02:07 PM   #14
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
So who did the work? By the way you initially presented this it sounded like YOU did the work involved, as opposed to contracting out to another shop.
Give credit where it's due man!!!
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 03-10-2015, 02:53 PM   #15
C. Ludwig
Rotary Masochist
Goopy I'm guessing. The big boost PR cars do this to provide clearance between the rotor face and the housing. It's not about lightening the rotor. If you really wanted to lighten it, you'd also mill the sides.
http://www.lms-efi.com
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
