Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > SakeBomb Garage
SakeBomb Garage SakeBomb Garage "OEM appearance, uncompromised performance"
Old 03-07-2015, 07:30 PM   #1
SBGarage
Driving The Rotary Sports
SBGarage's Avatar
SBGarage is on a distinguished road
Arrow SBG GB: Competition Electric Water Pump Upgrade Kit
Turbocharge your cooling system - SakeBomb Garage Competition Electric Water Pump Kit
The coolest thing to happen to the RX7. Ever.
If Mazda used a setup like this from the factory, countless motors could have been saved from overheating, warped housings, overheated and failed coolant rings, cooked turbos, and general rotary related heat woes. We've been revising this kit for over 8 months and are very excited to finally make this available to the FD community. Please forgive our lengthy thread, there is a ton of information to cover and we are doing our best to provide all of the necessary details and information in as readable of a format as possible. Please ask any and all questions, we expect quite a few considering the new technology.
Cliff Notes:
• Sustained coolant flow after shut down - Electronic controller allows pump to continue circulating coolant through your engine, radiator, and turbos after shutdown - prevents hotspots and boiling, and will even activate fans if needed.
• Flow optimized and contoured SakeBomb Garage Coolant Redirection Plate - Redirects coolant flow in place of mechanical pump with minimal turbulence.
• Efficient at all RPMs - Coolant pump no longer dependent on engine speed, so the pump is always flowing at optimal rate. Flow speed is now based on temperature, not RPM;
• User programmable pump controller - Pump speed is increased or decreased based on engine temperature. Real time control of pump speed to reflect engine cooling demands. Programmable set-points for maximum temperature and fan control. Mil-spec wire used on essential under-hood components. (optional LCD display controller available)
• Controller can trigger fans - removes the need for upgraded thermosensor (such as FC thermosensor).
• No mechanical drag on motor - 2-7hp (conservative estimate) regained by removing parasitic drag on motor. Increased throttle response.
• Increased reliability - Water pump belt slip is no longer a worry. No wax-pellet thermostat to fail.
• Goodbye turbo timers! Pump circulates coolant through turbos after shutdown.
• Low power draw - 8 amps at full speed.
• Easy to bleed cooling system - Without car running, just connect pump directly to a 12V battery. Pulse pump to bleed.
• -> Optional LCD Controller Upgrade <-
• -> Optional Custom 'Samco' Silicone Hose Kit <-
*Kit Requires removal of airpump, thermostat, and mechanical water pump. No wax pellet thermostat, so your car may take a few minutes longer to warm up, however the pump controller handles thermostatic functions based on temperature by varying pump speed (short pulses for pump at startup until operating temp is reached. (Upcoming "street kit" allows retention of mechanical thermostat, and stock airpump.)
The OEM pumps are (for lack of a better term) garbage, with the impeller made from folded sheet metal. Up until this year we've been using the ‘remedy’ machined mechanical pumps, however no impeller can be designed for optimal flow at all RPMs... you either under flow at low RPMs or cavitate at high RPMs. There is no one design that is optimal from 800-8000 RPM. The issue is that the pump (being mechanically connected to the motor) operates regardless of temperature and is forced to spin outside of its optimal range.
For example, if you’re overheating but your motor speed drops, you’re now moving less coolant when you need it most. Temperature, load, and RPM all become irrelevant factors with a mechanical pump tied to the crank pulley, it’s just along for the ride. The mechanical pump is forced to spin at the speed of the motor, and robs power to do it regardless of how much or little that pump really needs to be working. If we look at optimum pump speed, for a given condition the mechanical water pump is either under or over-cooling, under or over-spinning, or not spinning at all when you need it most (shutdown). Electric water pumps on the other hand can vary the pump speed based on the actual real time load demands for the cooling system and temperature of the coolant. It can spin as fast or as slow as required for the conditions to maintain the optimal engine temperature. New OEM applications tend to favor electric water pumps for a number of reasons, one being efficiency (no drag on the motor) and low power consumption (this one takes 8 amps max at full speed, and less as needed), but allows for other possibilities such as continuing to circulate coolant through the motor, radiator, and turbos after shutdown. The controller module we use also has the ability to trigger the fans if the temperature set point is exceeded after ramping up the pump speed. It’s an elegant solution and may end up rendering the mechanical water pump system in the FD a thing of the past.
Estimate of hp loss due to parasitic drag of mechanical pump (2-7hp loss depending on RPM - conservative estimate)
Prevents heat soak
o Runs after key-off to continue circulating coolant through the motor, turbos, and radiator – this prevents hot spots and boiling
o Electronic controller can trigger fans as needed to further cool the engine after ramping up pump speed - even while the car is off
o Coolant flows through turbos after shutoff - turbo timers are now redundant
o Pulls very little power (only 8 amps at maximum flow)
o Helps save turbo seals, coolant o-rings inside the motor, and prevents warping and hot spots from lack of cooling after shutoff
Maximum Cooling Efficiency
o Highly efficient impeller design - Optimized for maximum flow efficiency
o Standard mechanical OEM fitment pumps can be efficient either at high RPM or low RPM, but not both. Our electric water pump is de-coupled from the engine and is therefore efficient and effective regardless of engine speed.
Cooling On Demand
o Electric water pump operation is based on coolant temperature, and controller can modulate the speed of the pump in real time based on cooling requirements.
o Controller temperature settings are customizeable.
o Fans can be activated by the controller to increase cooling if temperatures continue to increase after max speed of the pump is reached. This is essentially a digital version of the "thermosensor" which is user-programmable.
o Belt slip on the mechanical water pump pulley is now a thing of the past!
o The end result of the system is the ability to activate maximum cooling even at low RPM, and after key-off.
Free Up Power and Throttle Response
o Save horsepower and increased throttle response by removing parasitic drag of mechanical water pump on the engine. 2-7hp depending on RPM.
o Only draws a maximum of 8 amps at full speed, and less as needed.
Contoured Design Tested for Optimal Flow
o 3D-optimized and contoured billet 6061 aluminum coolant redirection plate, milspec hard anodized.
o Contoured fluid path to drastically reduce turbulence and vortices forming in the water pump housing with the mechanical water pump removed
o Months of flow testing and revisions to create bowled output to fluid passage; this reduces turbulence by preventing quickly moving coolant from hitting a flat wall rather than smoothly directed towards the coolant inlet. The smooth flow contour aims to achieve as close to truly laminar flow as design constraints allow. Less turbulence means less flow restrictions and therefore more efficient and effective cooling.
o The plate has a C-ring that seats in the same beveled surface that the mechanical water pump blades do, forcing coolant through the flow path to the motor rather than whirl around and create turbulence.
Direct Mounting Location
o Located in lowest possible orientation to aid in most effective pump operation.
o Short and direct flow path to radiator.
o Electric water pump allows easier bleeding of coolant system. Connect pump directly to a 12V power source to manually circulate coolant through the engine without the caron. (With a manual pump, it usually takes days of topping up the system and heat cycling to thoroughly remove all air)
Specs
• 40 gallon per minute maximum flow rate
• 72.5 psi maximum rated operating pressure
• 8 amp maximum current draw
• Recommended operating range of -40°F to 266°F
• Aluminum pump housing for improved durability
• 7000+ hour manufacturer rated lifespan; equates to roughly 200,000 miles at an average of 35mph
• 2 year pump warranty
Follow us for product updates and more!
SBGarage is offline   Reply With Quote
Old 03-07-2015, 07:34 PM   #2
chibikougan
chibikougan's Avatar
coool!
Old 03-07-2015, 07:47 PM   #3
SBGarage
SBGarage's Avatar
What's included:
• SBG Coolant Redirection Plate, EWP 150 Pump, EWP Control Module, Recirculation Plug, Thermosensor, PnP Wiring Harness, and correctly sized (shorter) alternator belt included.
• Milspec wire used on essential under-hood components to prevent deterioration due to heat
• ->Optionally available with high quality Samco silicone hose upgrade - made to spec specifically for this kit<-
• ->Optionally available with Davis Craig premium LCD controller<-
* Removal of stock airpump, thermostat, and mechanical waterpump required for this kit.
Group Buy and Ordering:
We are offering a reduced price for the first 20 pre-orders of our Competition Electric Water Pump kits. These are first come first serve. Most parts are currently in stock however we are still waiting for a few last pieces as well as anodizing and finishing on our Coolant Redirection Plates. We are expecting kits to begin shipping within the next two weeks or sooner at this point. To reserve a spot you can do one of two things:
Payment in Full: Please visit the product page and submit payment in full. Your kit will ship as soon as it is complete. Order here -> SakeBomb Garage EWP-150 FD3S Competition Electric Water Pump Kit
Deposit: Please visit the deposit page here-> GROUP BUY DEPOSIT: SakeBomb Garage EWP-150 FD3S Electric Water Pump Kit to submit a non-refundable deposit payment. You will receive a coupon code emailed to you within a couple days good for the amount of the deposit. When you are ready to submit the remainder of your payment please visit the standard competition water pump product page here -> SakeBomb Garage EWP-150 FD3S Competition Electric Water Pump Kit Add the item to your cart, and enter your deposit code at checkout. You will have 12:00 MIDNIGHT MARCH 31st, 2015 PST days to complete checkout. Your code will not expire but the total price of the kit will increase after the pre-order is over.
Interest list:
0. SBGarage - Comp kit, standard controller, silicone hoses (GB Deposit PAID)
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Old 03-08-2015, 08:26 AM   #4
almoststockfc
almoststockfc's Avatar
almoststockfc is on a distinguished road
Could we see more pictures of the install?
-75 RE_W_PU -
-76 Hercules W2000 - DGRR 2012 3rd place Old School
-75 Hercules W2000 MSO - DGRR 2011 Peoples Choice - April 2011 Rotary of the Month
-Rotary snowmobile powered go kart - DGRR 2012 Peoples Choice - RIP
almoststockfc is offline   Reply With Quote
Old 03-08-2015, 04:09 PM   #5
ninesixtwo
sumdumguy
ninesixtwo is on a distinguished road
So what does this system use for a failsafe/warning in case of pump failure? I know EWPs are a relatively new item to the rotary market, but BMW have been using them in factory cars in tandem with electronically controlled thermostats for a decade now. There are very few things that kill an engine faster than a seized water pump
HKS T04Z Bridgeport FD3S
ninesixtwo is offline   Reply With Quote
Old 03-08-2015, 09:42 PM   #6
SBGarage
SBGarage's Avatar
Sure, what would you like to see?
We're working on a couple videos currently explaining everything better and showing some of the design process.
Old 03-08-2015, 10:33 PM   #7
SBGarage
SBGarage's Avatar
There's an optional LED light you can put in the cockpit that wires in to the controller to warn of a pump failure. The LCD controller has a built in audible indicator if a failure is present.
What's the fail safe for a failing stock pump? We've had many fail and our only indication is the temp needle moving up.
Old 03-09-2015, 09:20 AM   #8
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
Could this work for older engines like 12As?
Can I see a better front engine picture of the installed pump? I'm not seeing how it mounts
and the hose routing on the existing picture you have up.
Old 03-09-2015, 10:44 AM   #9
In for old school......
Old 03-18-2015, 12:36 PM   #10
SBGarage
SBGarage's Avatar
Here's a quick teaser video showing a bit of the flow testing and principles behind the design. We've got a more in-depth video coming but for now, here's a preview
Old 07-10-2015, 11:35 AM   #11
almoststockfc
Any updates? New installed photos? Specifically the water pump adapter plate fitment to the motor
-75 RE_W_PU -
Old 07-20-2015, 10:04 PM   #12
Garfinkles Motor Works
I pulled my motor today for some updates and paint, how much is this water pump kit.
