#1 |
ORD - Old Rotary Dude
Rep Power: 18 ![]() |
Headlights...no power
Any ideas as to why I am not getting any voltage (low or high beam) to the headlight plugs? Fuses and fusible link are good, I have 12v coming off of the switch, headlight motors work properly....just not getting any juice to either headlight plug.
Any thoughts? JTB 87 TII |
#2 |
Professional Stick Poker
Rep Power: 16 ![]() |
FC? If so check your headlight relays.
1988 N/A SE 2+2, dead stock and staying that way. ![]() 1979 SA22C stock? Not so much. http://rotarycarclub.com/rotary_foru...ad.php?t=15585 |
#3 |
IT'S ALIVE!
Rep Power: 17 ![]() |
Have you confirmed both relays still work? Power passes through both the headlight relay and dimmer relay regardless if the highs are on or not. A quick check would be if the high beam indicator illuminates when they're switched on.
EDIT: This. |
#4 |
Thanks guys. I will check them tomorrow. Thought I was going to tonight but opted to take my wife out for dinner.
#5 |
The issue was the headlight relay...or lack thereof one. Wired in a new relay and now HIDs with projector lenses work great.
Thanks for the help. JTB |
| Bookmarks |
