Old 02-04-2015, 08:30 PM   #1
WankelsRevenge
WankelsRevenge's Avatar
NRG Harness Bars
Im looking at getting a NRG Harness bar for my FC. Has anyone on here ever used one before? Im curious about opinions or pictures anyone may have.
Summary of this thread:
Old 02-09-2015, 01:48 PM   #2
Gregory Casimir
Wow I can't believe I missed this thread! I am currently running one in my FC ... but I the one I managed to fit in mine is for a Fox body mustang. So the size around 50" or so. I installed it for track day usage as the corning without restraints is a bit tough. I'm using Corbeau 3" 5 point harness. So mounting it was interesting cause I have automatic seat belts which left me to use the factory mounting holes for the rear seat harness which makes a lot more sense cause I've seen people bolt it to the rear hatch lift supports which is a bad spot for obvious reasons, not sure if it'll be the case for you for your model. The draw back I have from it is the storage bins only open about 45 degrees, I had to cut into my interior slightly, and I had to source out longer bolts to mount it. but other then that, I really am pleased how it turned out
Old 02-09-2015, 01:50 PM   #3
Gregory Casimir
and this how she looked 3 weeks ago at homestead speedway!
Old 02-09-2015, 02:05 PM   #4
WankelsRevenge
Well Im glad to hear it turned out good and is working for you. One of my biggest concerns is the harness I have is a complete bolt on one, so Im not sure how I could attach it to the bar itself, or if i could cut off the mounting tab for the shoulder harness part and source a way to attach it to the bar with a wrap setup.
Old 02-09-2015, 02:06 PM   #5
WankelsRevenge
This is the model I have
http://corbeau.com/other/harness-bel...ness-belt.html
if you can see what I mean about all the attchment points being bolt in style.
Old 02-09-2015, 10:23 PM   #6
Gregory Casimir
If you look at the pictures posted I wrapped mine around the bar. Pretty sure you could do the same with yours. Those hooks are removable, well for the rear at least.
Old 02-09-2015, 10:26 PM   #7
WankelsRevenge
awesome, always good to know then. where do you have yours bolted to in the rear?
Old 02-09-2015, 10:32 PM   #8
Gregory Casimir
Bolted as far as the side straps? Right where the stock ones are no need to change the position. Just I needed to get longer, high grade bolts to mount them as I'm still running the stock safety restraints
Old 02-09-2015, 10:35 PM   #9
WankelsRevenge
I ment the shoulder ones but then I looked at your pictures closer and saw you had the wrap style on the bar. Im sure Ill figure something out, if I even end up getting one.
