Old 01-11-2015, 09:36 PM   #1
sen2two
KTEC
sen2two's Avatar
Rx2 + 700 Miles = F*cking DGRR here I come, I hope. progress threqd.
My Rx2 hasn't been driven more than 5 miles since I owned it. Which has been a few years. It dosnt run right now and the front end is COMPLETELY taken apart. But I'm driving this damn thing to DGRR.
Here is my progress/build thread on the other forum. Way to many pictures to re-do it completely. Most of you here are there as well, so here's a link.
http://www.rx7club.com/old-school-ot...73-rx2-984536/
I'll update here as well from now on.
Who's caravan-ing from the Orlando or Central Florida area?
what I have:
What I had:
Old 01-11-2015, 09:38 PM   #2
sen2two
KTEC
sen2two's Avatar
Boom
what I have:
What I had:
Old 01-11-2015, 11:10 PM   #3
banzaitoyota
banzaitoyota is on a distinguished road
Iam going up I26 from Aiken SC, If you come up I95 we can meet at St. George and roll together. I'll be in my Duece
My deuce
banzaitoyota is offline   Reply With Quote
Old 01-11-2015, 11:13 PM   #4
sen2two
KTEC
sen2two's Avatar
Awesome!
I know, since I been wanting to do this for years, that they do caravan starting from somewhere in Miami all the way up. Have you ever linked up with a large caravan before? I'm not sure how it all goes down?
what I have:
What I had:
Old 01-12-2015, 08:50 AM   #5
Johnny_K
Johnny_K is on a distinguished road
Very cool. Good luck on the build look fwd to seeing it at the meet.
Johnny_K is offline   Reply With Quote
Old 01-12-2015, 05:50 PM   #6
banzaitoyota
Originally Posted by sen2two View Post
Awesome!
No, but I do not want to get involved in a herding cats situation. LOL
My deuce
Old 01-12-2015, 10:55 PM   #7
sen2two
KTEC
sen2two's Avatar
Sneak peak of the new CF hood and new old stock front lip.
what I have:
What I had:
Old 01-14-2015, 09:49 PM   #8
banzaitoyota
nice
My deuce
Old 02-03-2015, 06:03 PM   #9
sen2two
KTEC
sen2two's Avatar
I decided to make my own velocity stacks for now. The car will eventually become turbo as I do with everything. So these are being made in a way that they will become part of the plenum later on down the road.
First I turned down the body and made a step downed portion to fit into the Weber where it had been machined by Racing Beat. Then cut the OD and length. I made them 4.500" taller than the Webers with the stepped down portion being .500".
Then I made a press die to create the air horn shape. And pressed them to shape. One got a little slanted in the press and crushed the stepped down area so I had to make another.
[/QUOTE]
what I have:
What I had:
Old 02-03-2015, 06:06 PM   #10
sen2two
KTEC
sen2two's Avatar
]Here is some test fitting the unfinished product to make sure it's all good before shaping.
And here is the finished product.
[/QUOTE]
what I have:
What I had:
Old 02-03-2015, 06:59 PM   #11
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Very impressive work. Way cool.
Old 02-03-2015, 07:15 PM   #12
banzaitoyota
Nice.
My deuce
Old 02-04-2015, 04:12 PM   #13
sen2two
KTEC
sen2two's Avatar
I made some plugs today for the now useless trailing plug holes. I basically used my spare Rx8 plugs and removed the ceramic and associated crap from the rear of the plug. Then welded a piece of sheet metal to close it up. Then finished it off in the lathe to look like an actual bolt head. For the other end I also welded it shut and finished off the end. I will make a "cooler" set in the future. But there will get the car running for now.
what I have:
What I had:
Old 02-05-2015, 09:40 PM   #14
sen2two
KTEC
sen2two's Avatar
Here's a pic of how the oil lines fit. You can see just above the lower oil cooler line I marked a spot I was going to originally mill a radius in, but it fit without having to. And above that the 180° fitting sits in its spot.
And a shot from above. I am debating on adding a brass washer to the passenger side oil cooler line that is exiting the oil cooler. It just almost a perfect strait line to the front cover line. It's less noticeable in person. But this picture bothers me enough to make it perfectly strait....lol
what I have:
What I had:
Old 02-05-2015, 09:45 PM   #15
sen2two
KTEC
sen2two's Avatar
And one final shot of the stacks installed in there finished state. I took a scotch brite pad to the inside and radius the edge of the bell mouth on the lathe with a file. They look much more professional with those two minor touches.
what I have:
What I had:
