Old 01-08-2015, 03:42 PM   #1
yteemzayed
yteemzayed is on a distinguished road
Apexi FC Tuning .
Hello Everyone ,
i am kinda new to the rotary engine mods and tuning , and my FD got a Apexi FC and the tuning ruined idk why , and most of the garage's here don't work on rotary engines , could someone tell me , is it different from normal piston tuning ? and if yes , why ?
- mine doesn't have much mods ,
the mods are : Blitz intercooler
, intake
, 1600 bosch injector
, walbro fuel pump .
yteemzayed is offline   Reply With Quote
Old 01-08-2015, 03:53 PM   #2
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Where do you live?
I'm NOT a tuner, though we've got plenty floating around on here. That being said, from what I've heard the rotary is def a bit different than standard piston engine tuning. I think it boils down to the timing split required and staging the different sized injectors.
Obviously you'd be better off with legit advice on the differences coming from one of the members on here that tune for a living.
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 01-08-2015, 03:58 PM   #3
Tuning process is the same.
Base maps can be significantly different.
Old 01-08-2015, 04:03 PM   #4
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 01-08-2015, 04:14 PM   #5
RICE RACING
Don Mega
RICE RACING's Avatar
Originally Posted by yteemzayed View Post
Hello Everyone ,
, intake
These days with the internet you are best off paying someone like me to do this remotely for you, see my web site for examples on main page.
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-08-2015, 04:59 PM   #6
What Rice Racing said....
You don't want someone who does piston engine shit to tune a rotary, there are too many variables.
You basically have two options, find some who has dealt with rotaries for decades, has worked or owned a rotary shop, has a running car that has survived years of abuse, (track and street) makes actual HP and runs and drives like a stock car, and can prove it to you. These people will tune your car on the dyno and street.
Someone like RR can SCIENTIFICALLY tune your car via emails and sending MAPS where as most tuners (me included) tune on the dyno/street.
Old 01-08-2015, 04:59 PM   #7
Where are you located?
Old 01-08-2015, 05:04 PM   #8
yteemzayed
i am from Dubai :X
Old 01-08-2015, 05:38 PM   #9
Road TRIP!
Old 01-08-2015, 05:43 PM   #10
i am from Dubai :X
Yeah, Peter (Rice Racing) is the/your man for the job
Old 01-08-2015, 05:55 PM   #11
yteemzayed
I'll contact you RR
Old 01-08-2015, 06:42 PM   #12
RICE RACING
Don Mega
I'll contact you RR
Too easy. Just go to my page and click on the link, it will automatically fill out the email message for you
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-08-2015, 07:14 PM   #13
RICE RACING
Don Mega
Here is example of a 'consultancy customers file'............ It's extensive and NOT a typical 'mail order tune' from some f*ckwit
^ Just sent this now to a US customer who ordered a RRWEP140 water injection kit and tuning support
Had a customer yesterday who ran 9.27 seconds at 149mph in his road car in New Zealand he gags over the WI and tuning advise I give
Little report changed customers rx3 finally from c16 to wm50 98 petrol ran it last nights test and tune pb'd with a 9.27 at 149mph bettering the c16 time of 9.34 stoked as Dean. Boost was 33.5psi
It took a while to sort on the dyno had alot of rich missfiring so was showing it as lean on afr, likes to be around 10.8s to 11.5s seems to have a big window when tuning, cleaned up the top end at the track and it took off.I have not tuned any on straight water so are thinking that straight water can tune richer.
- Original Message -----
Hey pete that timing map i got off you a while back, is that working from a static of tdc. So 3.8bar 40.6psi you running 7.75 degrees and on what rotors. Don't worry all confidential thanks Dean. fuking love this water. Owner can't believe how cheap it is to run.
----- Original Message -----
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-13-2015, 11:16 AM   #14
Lex
Lex is on a distinguished road
Hello,
Your website is very hard to navigate and I can't seem to find the link to email you. I'm looking for PFC tuning as well. Does your service require a datalogit to pull logs. I'm new to rotaries and engine tuning all together.
Thanks,
Alex
Lex is offline   Reply With Quote
Old 01-13-2015, 08:00 PM   #15
RICE RACING
Don Mega
Originally Posted by Lex View Post
Hello,
Thanks,
Alex
Hi Alex,
I am not an internet person, I just smash up as much detail as I can and have it simple enough, out of 10 people one will say what you are, the other 9 will say its sicker than tits............ so I leave the web site as is to suit the majority who love it.
Now onto your question:
* You will need a datalogit
* You will need some familiarity with computers
* You will need an AFR instrument hooked into the datalogit (one that your trust)
If you meet all that criteria then I can help you.
The other thing I do is send out programmed ECU's so it has a base in it that you can take to your local person or you yourself can screw around with on the hand set interface.
E-Mail me for details on that.
Peter
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
