Old 04-18-2008, 04:17 PM   #1
BLKTOPTRVL
BLKTOPTRVL's Avatar
Rebuild Questions
What is this? It is on the upper fuel rail. It appears there is a diaphram of some sort located in this housing.
I have not disassembled this because it has given no sign of failure; however, since I have the engine appart, if there is an inexpensive replacement I'f like to know about it.
Any input?
Thanks.
Old 04-18-2008, 04:21 PM   #2
BLKTOPTRVL
BLKTOPTRVL's Avatar
During Disassembly, I broke the air intake off this solenoid...
Since it is a air intake, I imagine, I could superglue it back on, but just for laughts, how much is a replacement? Anyone have a used one they want to sell?
I am assuming all four are identical?
Old 04-18-2008, 04:24 PM   #3
BLKTOPTRVL
BLKTOPTRVL's Avatar
I guess this is the famed Pulsation Damper.
In 19 years, this one has never leaked, but since getting to it is a PITA, I might as well check out a replacement now. Last price I saw was about $150 (I will call Ray for a price on all the items in this list) but if anyone knows of a better price/souce, I'd appreciate hearing.
Old 04-18-2008, 04:26 PM   #4
BLKTOPTRVL
BLKTOPTRVL's Avatar
These upper and lower rail injectors look to be exactly the same. Are they? If not, how do I tell them apart?
Old 04-18-2008, 04:29 PM   #5
BLKTOPTRVL
BLKTOPTRVL's Avatar
Wire Harness General...
As I have been disassembling the car, I have been hearing crackling noises from the wire loom and the covering tape (and hopefully not the wires) crack as they move.
Anyone had a bad experience with needing to replace the harness or part of the harness after a rebuild because the wires were too hard and broke?
Old 04-18-2008, 08:41 PM   #6
Any input?
That is your fuel pressure regulator.
Old 04-18-2008, 08:43 PM   #7
The one with the gray sticker, right?
That's not on a turbo model, so I can only guess...
If it's a kouki FC, it's most likely VDI?
(After looking at your fuel injectors, you look like you're running a zenki FC non-turbo - most likely 6-port?)
If you're talking about the "mushroom" part, it's just an air filter.
Yes, most of them are swappable.
It's a matter if they are "NO" or "NC".
I haven't confirmed if they are all one type of another.
Never priced them brand new from the Mazda dealer, since most guys chuck them when ripping out emissions - pretty easy to find used.
Old 04-18-2008, 08:44 PM   #8
That is correct.
Old 04-18-2008, 08:45 PM   #9
That is correct.
All stock FC fuel injectors are identical.
If you wanna keep track of where each were originally located, you need to mark them.
You can't really tell them apart.
Old 04-18-2008, 09:17 PM   #10
BLKTOPTRVL
BLKTOPTRVL's Avatar
Never heard this terminology... Kouki (kooky )
Yes, I am speaking of the grey one. And these photos are from my 6 port 88 vert.
It's good to know they are common, I will cast about and see what I can find.
Thanks again Ted. Always Helpful
Old 04-18-2008, 09:19 PM   #11
BLKTOPTRVL
BLKTOPTRVL's Avatar
That is correct.
They were sent out to be rebuilt, so which is which doesn't concern me now.
Old 04-18-2008, 11:07 PM   #12
I like to use the Japan terminology when talking about the year splits...
1986 - 1988 = S4 = Zenki
1989 - 1991 = S5 = Kouki
Old 04-19-2008, 06:49 AM   #13
Apac tii
Apac tii's Avatar
Apac tii is on a distinguished road
Kouki is another term for a s5 2nd gen rx7, zenki is a s4 model.
1988 Mazda RX-7 T2(list of mods here)
http://designengineeringworks.com/project_cars.php
2004 Saturn Ion Redline(dd)
1999 Mitsubishi Galant V6(the backup beater)
Apac tii is offline   Reply With Quote
Old 04-23-2008, 03:41 PM   #14
BLKTOPTRVL
BLKTOPTRVL's Avatar
Engine is now ready to come out, every external system has been removed and the tranny/exhaust is disconnected.
My biggest surprise so far is that not one of the bolts has been any real trouble. (knock wood).
Question:
The top engine/trans bolt behind the oil pedestal at first wanted to round, so, I used a couple of other wrenches and it came right out. Anyone have a source for hardened bolts so I can replace it?
Old 04-23-2008, 04:15 PM   #15
classicauto
crash auto?fix auto
classicauto's Avatar
The tranny bolts don't need to be anything suepr special. Just take the to a hardware store and grab the proper length and dia/pitch (M12/1.25 IIRC, but don't quote me )
