Old 11-30-2014, 06:07 AM   #1
seanbumalmighty
seanbumalmighty's Avatar
seanbumalmighty is on a distinguished road
Hi from mass
Hello everyone my names Sean I'm from Massachusetts and I drive a 1993 fd3s with some mods. Looking to do an na renesis swap at some point next year. Possibly a 3 rotor . Look forward to some good post as well as info thanks..
seanbumalmighty is offline   Reply With Quote
Old 11-30-2014, 11:53 AM   #2
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Welcome. Personally I'd go with the 20B 3 rotor or stay RE/REW with a good build. Renesis would be a lot of work and money to be going backward power wise.
Old 11-30-2014, 11:59 AM   #3
Welcome!
I agree with Gunny. At least price it out before you start. I've thought recently about having to move to Renesis engines when older 13B parts start drying up, but I'm not exactly excited about it. I don't know why they couldn't make more power, but it seems that's the case. I could be wrong about all this though haha.
The Cosmo 3 rotors seem like they're coming down in price as of late. It would still be an expensive swap, but at least you wouldn't be reinventing the wheel and there is already some support out there.
Just out of curiosity, what are your reasons for wanting to go Renesis 3 rotor?
Old 11-30-2014, 02:34 PM   #4
seanbumalmighty
sorry I meant renesis or three rotor my mistake... my motor is getting tired 105psi front 100 rear and renesis are fairly cheap and I want na for reliability aspect plus I really like na and plan on doing a time attack car. na 20b would be awesome as well but so $$$$. I had a Honda time attack car that I never got to run . I just like trying to get as much out of a na as possible! I guess im weird but I like na the best and I like trying to see what I can get out of an na time wise and rev wise etc.. I dunno.. I know its expensive so when it comes down to it I will more than likely rebuild my motor...
Old 11-30-2014, 03:05 PM   #5
GySgtFrank
GySgtFrank's Avatar
I hate to say this as I like NA engines as well, but to make power naturally aspirated you need displacement, which is big bucks. Otherwise you have to go peripheral port and put up with the trade offs on the street. Even then, 250hp is probably the outer limits and will most likely cost about the same as the 20B with not so hot reliability. You're only working with 80 cubic inches, so there's only so much you can do NA. The combustion cycle of the rotary helps, but it's still a small engine.
For a heavier car like the FD a single turbo, low compression ratio engine (running moderate boost) is probably going to be the most reliable rotary you can build. At least one that makes the kind of power you will need for the FD. Just don't make the common mistake that most others do and start putting together all the sexy go fast stuff on the engine and not do a massive upgrade on the fuel system and ECU. Without those any boosted rotary is likely to implode, no matter how good the engine build was.
Old 11-30-2014, 03:22 PM   #6
seanbumalmighty
yeah I agree the more I think about it the more I figure ill go with the 13b rebuild. I posted a build thread so you can check out what she has already.. It has pfc for ecu but needs a tune...
Sean B.
1993 FD3S Touring
Old 11-30-2014, 04:41 PM   #7
chibikougan
chibikougan's Avatar
Get in contact with RICERACING for the PFC
