Old 10-14-2014, 09:32 AM   #1
FC Zach
FC Zach's Avatar
2nd Gen Electric Fan Mounting Recommendations
I'm looking for a mount system for an electrical fan to use on my Koyo rad rather than using these:
My universal fan recently removed:
The mounts for that fan:
Damage from the fan sliding off those mounts on the radiator:
What I'm looking for is to delete the zip-tie mounts, using a fan with permanent mounts that will work with the 2nd gen Koyo, or ideas on fabricating my own for a particular dimension fan that I can make fit my Koyo without use of the universal zip-ties. . . what have y'all used?
I made measurements of the cooling fin surface and all possible mounting points but I am stumped with what fan to buy, curious of anyone's opinions for options/suggestions. .
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 10-14-2014, 11:27 AM   #2
rx7 vinnie
I SEE DEAD PEOPLE
rx7 vinnie's Avatar
This is mine... A custom made shroud with a 3k cfm Flex-a-Lite fan mounted about 3" away from the radiator to draw vacuum.
03 Dodge Viper SRT-10 Vert
16 MB ML350
Old 10-14-2014, 12:35 PM   #3
very nice vinnie
Old 10-14-2014, 01:00 PM   #4
FC Zach
FC Zach's Avatar
Yes sir, that is very nice! Think you could have another one made?
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 10-14-2014, 01:09 PM   #5
rx7 vinnie
I SEE DEAD PEOPLE
rx7 vinnie's Avatar
YUPP.... You have my number.
16 MB ML350
Old 10-15-2014, 12:48 AM   #6
FC Zach
FC Zach's Avatar
Problem solved! contacted the fabricator Vinnie used and will soon make a visit. Thanks Vinnie!
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 10-15-2014, 05:52 AM   #7
rx7 vinnie
I SEE DEAD PEOPLE
rx7 vinnie's Avatar
Np dood.
16 MB ML350
Old 10-15-2014, 12:39 PM   #8
infernosg
IT'S ALIVE!
infernosg's Avatar
I made my own out of fiberglass. Here's an unfinished picture:
And one mocked up under the hood:
I'm curious about the aluminum one above. Does it have some contour or is it more of a "box?" I liked the idea of an aluminum shroud but didn't have the provisions to make a nice, contoured shape. The good thing about a flatter aluminum shroud is it's easy to make "flaps" that open when the car is moving to improve flow.
Old 11-25-2014, 05:50 AM   #9
FC Zach
FC Zach's Avatar
Got mine made, now Vinnie and I are twinsies
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 11-25-2014, 07:55 AM   #10
infernosg
IT'S ALIVE!
infernosg's Avatar
^^^ To restate my previous question is the shroud "flat" or does it have some contour to it? From the picture it looks to be more flat. On the other hand it looks like you could easily add "flaps" that open when the car is moving to increase airflow when the fan isn't needed.
Old 11-25-2014, 08:38 AM   #11
FC Zach
FC Zach's Avatar
Yeah Jon, it's flat. I have the largest diameter fan that could fit on there thinking it would remedy that possible issue.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 11-25-2014, 09:56 PM   #12
rx7 vinnie
I SEE DEAD PEOPLE
rx7 vinnie's Avatar
Looking good broseth...... But mine is slightly different at the outlets so no twinsies for you.
16 MB ML350
Old 11-26-2014, 07:28 PM   #13
FCFrog
FCFrog is on a distinguished road
Sweet
FCFrog is offline   Reply With Quote
