Old 08-18-2014, 06:52 PM   #1
ran83
ran83 is on a distinguished road
Exclamation in need of some serious clutch help
So I Baught a new clubch that is a stage 2 (what ever that means) it is rayed for 350 hp. Any way I pulled the tranny and old clutch replaced the fly wheel and bolted everything back up. I have bled the s#!+ out of the slave cylinder and the clutch engages when the pedal is about a half inc off the floor and slips? What could be the problem I have changed many clutches (not rx7) amdhave never had any problems!any thing will help
ran83 is offline   Reply With Quote
Old 08-18-2014, 10:41 PM   #2
FC Zach
FC Zach's Avatar
Did you unbolt the slave cylinder or remove the line to it? just curious why you had to bleed the system.
Assuming there is nothing wrong with your hydraulics my next question is, were all the replacement parts correct i.e. throwout bearing? May be a dumb question but in my experience the supplied throwout bearing isn't always the best part to use.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 08-19-2014, 09:39 AM   #3
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
Clutch disk backwards? Missing throwout bearing? Assembly error?
