Old 07-27-2014, 07:49 AM   #1
Warning Light Cluster problem
Yesterday all of the idiot lights in my warning light cluster with the exception of the brake & check engine light lit up and stayed on with the car running. The clock in the cluster still works fine, and I've done the cold-solder joint fix on the cluster years ago to correct the wonky clock. This is on an S5T2. Since I needed get somewhere, I just shut it off and switched to the daily driver.
I seem to recall this is "normal" idiot light behavior for FC's when you have an alternator/charging system failure - rather than just the "Charge" light coming on. Can anyone confirm this?
If true, then I should check out my charging system today. Assuming that checks out good, could this be another symptom of cold solder joints in the warning light cluster?
Old 07-27-2014, 10:16 AM   #2
You're on both right tracks Pete.... I wouldn't be surprised if the alt puked or the belt broke
Old 07-27-2014, 11:11 AM   #3
Checked the charging system out this morning, looks like my alternator puked... Belts are fine & tensioned properly. Did some quick DVM measurements with the engine idling resulted in only 11.4V with no extra accessories on, which dropped to about 11.2 with the headlights on & heater fan running @ max. Shutting the engine off and taking the same measurements resulted in 12.5V with lights off and 11.9 with lights on, so the battery is healthy.
Old 07-27-2014, 11:35 AM   #4
On another (related) topic, since I'll need to replace my alternator, I'd like to replace it with one of those higher than stock output current (> 100 Amps) drop-in alternators. There are a number of shops out there that build these, some more reputable than others. Was wondering if anyone had any experience with this that has a good shop to recommend?
Old 07-27-2014, 06:50 PM   #5
I'm going through a bunch right now...
I already run an FD alternator on my FC 13BT.
I've got a "160A" FD unit off of eBay for like ~$160.
It's a disappointment.
The damn thing barely idles @ ~13.0VDC.
Loaded down at idle, it runs about 12.0VDC.
The seller was named "HighAmpSpecialist" or something like that.
One of my previous posts talks about having good experience (rebuilt starter for my FC) from an eBay seller "AceAlternators" (or something like that), but they don't offer an FD unit anything over 130A now...
They used to have a 160A, but I haven't seen that unit for sale for a few months now.
There's another eBay seller called B&R or something, and they offer FD alternators in the 160A range for about $200?
Check the feedback. and there's negative comments of the upgrade alternators being bullsh*t.
I would highly recommend to go with a MechMan unit if you got the bucks...
Last time I checked, it was about $330?
Yes, it's a little pricey, but these things are rated like 250A...
http://www.mechman.com/
Old 07-27-2014, 08:53 PM   #6
I'm not sure these really hi Amp alts are all that necessary unless you're running one or a few accessories that pull some serious Amps...
I run a stock FD alt and I seem to not have voltage issues. Although I've rewired the car and the charging and the main distribution wires so voltage loss isn't a concern to me.
That being said I don't get a full 14.4volts, it's usually around 14.1-14.2 but I'm still playing around with resistance values on the excite wire.
Old 07-27-2014, 09:23 PM   #7
2gslse
Pete, I would just run a stock FD alternator on your car and get the correct pulley to run the v-belt. I am running a FD alt on my FB and have 2 044 bosch pumps, 17" electric fan, electric PS pump and all the other power goodies and it keeps up fine so far.
2006 VW TDI commuter
Old 07-28-2014, 04:38 AM   #8
A stock FD alternator should have enough juice for anything I'm running now, plus whatever I might add down the road (e.g., stereo upgrade/e-fan).
Yup, I recall you mentioned AceAlternators on ebay, and took a look there. They have S5 drop-ins for about $140 that are rated 110A, which is roughly the same as a stock FD alternator. They didn't show anything in stock above 110A. One year warrantee on it FWIW. I might give them a shot as it's enough juice for my current & future needs, and I can reuse the dual belt pulley I already have.
Also heard good things about the Mechman alternators, but that is overkill & too much coin for my needs.
Stock S5 alternator is about 70~80A at most; I'm just looking for a better reliability margin to ensure the fuel pump gets enough juice when I'm running all the stock electrical loads, and any future changes (big stereo, e-fan, etc.). So something in the stock FD range (100~110A) should be fine.
Old 07-28-2014, 11:40 AM   #9
Just for reference...
1987 Turbo II
13BT
Haltech E8
Electric fan - measured @ 17A of steady-state current pull
HID's - "35W", 4300K
Stereo:
Alpine 7618
Rockford Fosgate PA-1HD
Rockford Fosgate EPX2
Currently running an Adcom GFA-5275, but have also ran Harman Kardon CA260, Precision Power 2075AM, Adcom GFA-4403 (bridged)
Only running a pair of separates at the moment: originally a Diamond Audio D3 D351, but tweeters were bad, so replaced them with some Polk DB1001's
Everything on (at night), the HKS voltmeter will dip under 12.0VDC.
My original silverrotor FD alternator was able to hold 13.0VDC, but it had a problem with shutting off the exciter field in the alternator when keying off.
I am more comfortable having everything over 13.5VDC at idle with it loaded down, and ideally 14.5VDC...
I am eyeing the Mechman alternator, cause it claims it'll pump out 100A of current @ idle!
Old 08-01-2014, 01:12 PM   #10
FWIW, I ended up picking up that 110A alternator from AceAlternators on ebay. I have no means of measuring current draw to verify the 110A upgrade, but here's the voltages I'm seeing with it:
@ 750 RPM idle, low beams on + fog lights on + A/C fan on max = 12.6V. Nudge the idle up to 850 RPMs or higher, and it goes up to ~13.6V.
With same loads switched off, from low idle and up nets between 13.6~14.5V.
Also I have an alternator installation tip that might be useful if anyone runs into the problem I had. This particular alternator didn't want to slip over the water pump housing at the pivot point - it was maybe a few thousands of an inch too tight, and there was no persuading it to fit. After much cursing, and considering shipping it back, I had a brilliant idea... Just loosen the 4 bolts that hold the alternator halves together about a 1/4~1/2 turn each; that "spreads" the alternator half's just enough to get it to slip over the water pump housing pivot point. Once the pivot bolt was in, I just tightened the 4 alternator bolts back down and everything was fine.
Old 08-01-2014, 01:54 PM   #11
That's interesting.... generally the nut on the alternator case itself will slide in and out. I have a dedicated 1/4" extension that I use for beating shit with.... slide that through the bolt hole, offset it a little and beat on it... or... use the mounting bolt itself, thread it in a few threads and pound away on the head - giggitty
I've swapped many an alternator case from powdercoating and what I've noticed is if the halves aren't PERFECT, it sounds like shit and the bearings will probably go bad quickly. O would take the alt off and make sure the halves are tight and true, it spins very easily by hand, follow the above tip and put everything back together.
Cheers
Old 08-01-2014, 01:56 PM   #12
Oh... good to know someone has replacement alts pretty cheap... curious as to how long it lasts though... I generally don't have good luck with reman'ed alts. Can't tell if it's the salt air, or the eff'ed up wiring that I had been using in the past....
Old 08-01-2014, 02:32 PM   #13
I picked up a Mastech MS2108A as a cheapie option for now.
You can get them for under $50 shipped - check eBay and Amazon.
Until I can scrape up the skrillah to get a Fluke for several hundred $, the Mastech is "close enough" - who cares if it's off by 20%?
It sounds like you got a better unit than I did.
I've never seen mines go over 13.9VDC, and it's an FD unit rated to 150A... :P
