Old 06-23-2014, 06:28 PM   #1
tweiss3
Mazda Lover
tweiss3's Avatar
Front wheel hub
So my passenger front wheel bearing is shot. It's pitted on the races in the hub, so I ordered a new inner and outer bearing plus the seal. The thing is I can't figure out how to get the old races out. The FSM seems to say you must replace the hub as well, but that just doesn't make sense.
Is there a good way to remove the inner races?
Old 06-23-2014, 06:53 PM   #2
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
You have to grind a couple of small slots on the backside of the hub where the race seats, just enough to get a small punch on the back side of the race. Then, using the punch. work the race out of there. Re-assembly is straightforward, just drive the new races all the way down just like any other wheel bearing replacement.
Old 06-23-2014, 06:56 PM   #3
tweiss3
Mazda Lover
tweiss3's Avatar
So slot the aluminum between the two races, then us a punch? I suppose that makes sense. I'll give it a shot tomorrow.
Old 06-23-2014, 07:03 PM   #4
GySgtFrank
GySgtFrank's Avatar
Yep. As you found out Mazda meant for the entire hub to be replaced when the bearings went bad. Therefor they left no provision to remove the races. I love the engineering and thought that Mazda put into these cars, but this and a few other things, make me think they spent too much time with the Ford marketing group.
Old 06-23-2014, 08:52 PM   #5
Looks like you got the answer already, but here's a good FAQ on the procedures with pictures, courtesy of MazdaTrix...
http://www.mazdatrix.com/faq/frontbrg.htm
Old 06-24-2014, 06:35 AM   #6
tweiss3
Mazda Lover
tweiss3's Avatar
Thanks, that mazdatrix makes me feel better, I was worried i'd make too big of a notch, but they ground that notch pretty large.
I don't understand why the bearings are sold with an inner race if the idea is to replace the entire hub, but I'm glad it's not too bad to figure out.
Old 06-24-2014, 12:41 PM   #7
chibikougan
chibikougan's Avatar
S5s have all sorts of fun must replace items. Engineered for making money.
Old 06-25-2014, 08:56 AM   #8
Turbo II Rotor
Turbo II Rotor's Avatar
Got a welder? Throw a bead around the inside of the race. This will shrink the race a little bit and you can usually flip the hub over and bang it on the bench and the race will fall out.
http://blog.hemmings.com/index.php/2...bearing-races/
Old 06-25-2014, 08:33 PM   #9
Garfinkles Motor Works
I have done the welding method and the grind , hammer and drift method. I like the notch method because once the notch is made it is ready for the next set of bearings .
Old 06-26-2014, 05:48 AM   #10
tweiss3
Mazda Lover
tweiss3's Avatar
I did the notch method last night. It worked out pretty well, but it definitely took more time than I initially anticipated.
Old 07-09-2014, 12:42 PM   #11
Tanj!
Tanj!'s Avatar
Tanj! is on a distinguished road
Another option is to place the entire hub in the oven at 200*F for 10 to 15 minutes. The aluminum hub expands faster than the steel bearing race. You can then just flip the hub over and give it a good whack with a hammer and piece of wood. The race generally just falls right out. Sometimes a little more persuasion is needed.
Tanj! is offline   Reply With Quote
Old 07-10-2014, 03:53 PM   #12
I took a torch to the hub and eventually the race just fell out since the hub expanded faster than the race. Similar to above, just more targeted heat.
Old 07-10-2014, 09:33 PM   #13
Because bearings are generally generic, so that one bearing could fit a host of other things that have provisions for replacement races.
