Old 06-06-2014, 06:49 AM   #1
sen2two
KTEC
sen2two's Avatar
Mount coils directly to the plugs
so I am not using a traditional coil on plug piece. I am using an MSD SS coil on a my 12a for direct fire set up using HEI igniters (TFIDFIS). I want to mount my coils directly to my spark plug. But the only straight boots I can find are for coil to wire.
Anyone know where I can find a coil boot that will let me go straight from coil to spark plug?
what I have:
What I had:
Old 06-06-2014, 01:48 PM   #2
I don't know if this is a good idea...
Electronics do NOT like:
1) Heat
2) Vibration
Putting the coil on the spark plug just increased both.
The only way to combat this physics is just reduce the mass...
This is why Coil-On-Plug designs (for OEM) use a pretty small coil.
So, you're just reduced your coil performance just to get rid of the spark plug wire???
I'd rather run a honking, big coil and run traditional spark plug wires...
Unless you're RICE RACING with a LOT of money!
Old 06-06-2014, 04:07 PM   #3
sen2two
KTEC
sen2two's Avatar
I don't see how they will see any more heat or vibration than mounting them on the strut tower as is normally done. Or on the motor which is often done.
Realistically the difference is a few inches, so the heat problem is a non-issue. Since these coils will be mounted on a plate which is attached to the motor. There will be no movement difference between the plugs and the coils.
After heavy searching, I have come to the conclusion that they do not make a boot for this. So I guess I will be making my own.
what I have:
What I had:
Old 06-06-2014, 05:48 PM   #4
Let me get this straight...
You want to mount your coils onto something other than directly onto the engine / spark plugs?
You don't want to use spark plug wires?
Does that sum everything up?
Did I miss anything?
Old 06-06-2014, 06:12 PM   #5
chibikougan
chibikougan's Avatar
http://www.rx7club.com/3rd-generatio...-packs-864760/
I believe you have to cut down the spark plug also.
Need a trigger and something to drive 4 2 wire coils.
Build a custom mount.
Good Luck
Old 06-06-2014, 07:30 PM   #6
sen2two
KTEC
sen2two's Avatar
I just tried to draw it up in SolidWorks so I can post a 3d rendering, but of course the program is giving me an error. pictures are worth a thousand words, and even more in this scenario.
What I am trying to do is, make a mount that will be attached to the engine. This mount will hold the coils/igniters directly in front of the spark plugs also acting as a heat sink. The spark plugs will be connected directly to the coils through a boot that I will make, since I do not believe they make this type of boot.
Please note that this is not for a fuel injection motor. These are 2 Blaster SS coils (8207) using HEI igniters, with a 85 distributor (TFIDFIS). Using with no trailing ignition at all.
what I have:
What I had:
Old 06-06-2014, 07:35 PM   #7
chibikougan
Did you ask just to tell everyone what you are going to do?
Seems like you have it figured out.
Good luck
Old 06-06-2014, 08:18 PM   #8
sen2two
KTEC
sen2two's Avatar
Good luck
I posted thinking that maybe somebody would know where to get one of the boots to mount a coil to a plug. I never asked a question on how to do it or if it would work. Only where to get the part.
what I have:
What I had:
Old 06-06-2014, 08:38 PM   #9
chibikougan
Here
http://www.google.com/#q=coil+to+plug+boot&tbm=shop
Old 06-07-2014, 07:47 AM   #10
sen2two
KTEC
sen2two's Avatar
Thank you, but none of those will work. Those are all factory replacement parts. I already started to make my own.
what I have:
What I had:
Old 06-07-2014, 08:17 AM   #11
C. Ludwig
Rotary Masochist
Magnecore may be able to make something work. They have a huge variety of boots. We looked at doing this with the IGN-1A coils and there was not enough room between the plugs and the frame rail.
http://www.lms-efi.com
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 06-07-2014, 09:26 AM   #12
sen2two
KTEC
sen2two's Avatar
I have also looked at doing this for my Rx8. I was planning to use the IGN-1A coils as well. I am thinking now that making a 90 degree boot to attach the coils might work if you get creative with mounting angles. I am unsure if there is sufficient room though.
what I have:
What I had:
Old 06-07-2014, 12:16 PM   #13
chibikougan
So the direct 90° angled one made for your coils are factory replacement..?????
Good luck...
Old 06-07-2014, 03:37 PM   #14
sen2two
KTEC
sen2two's Avatar
Good luck...
If you are referring to the MSD part 3331, that is for coil to plug wire. That will not work from coil to spark plug.
what I have:
What I had:
Old 06-07-2014, 04:07 PM   #15
chibikougan
Nope.
You got it figured
Edit: I am excited to see what you have come up with. Get on it
