| Rotary Tech - General Rotary Engine related tech section.. Tech section for general Rotary Engine... This includes, building 12As, 13Bs, 20Bs, Renesis, etc... |
#1 |
Clean S4 Nutswinger
Rep Power: 18 ![]() |
Painting heat exchangers
My FC's oil cooler is looking shabby these days, so I was thinking of cleaning it up and spraying it with some aluminum colored high-heat spray paint. Are there any potential issues with having paint covering any heat exchanging surfaces?
-Ted -1986 Mazda RX7 Sport [DD/beater]: engine finally let go at 205k. parts car status. -1986 Mazda RX7 base [resto-mod project]: S5 n/a swap in progress.
#2 | |
http://www.newton.dep.anl.gov/askasc...9/eng99320.htm
http://www.eastwood.com/eastwood-rad...ack-paint.html
#3 | ||
Clean S4 Nutswinger
#4 | |||
Half bubble off plumb
Rep Power: 17 ![]() |
Don't know what you read, but according to one reply... Dont do your planned silver, just do black J.
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it." 360 gamertag: Tichlis |
#5 |
Clean S4 Nutswinger
Yes, I suppose black would look better than old, dirty aluminum.
#6 |
Rep Power: 16 ![]() |
Why not just give it a thorough cleaning and call it a day? A good degreaser/engine cleaner and a pressure washer will do wonders on an AL oil cooler.
You'll have to get it really clean anyway before you paint it if you want the paint to last. |
#7 |
Clean S4 Nutswinger
I'm just concerned about it getting all dull again once exposed to the elements without any kind of coating. You are right though, I will have to clean it thoroughly to paint it, so I'll see what it looks like at that point and make a decision.
#8 |
Rep Power: 19 ![]() |
Almost any "paint" is going to introduce a layer of insulation.
This goes counter to what you want in an efficient heat exchanger. The only exception is perhaps (aluminum) anodizing, which is basically a dye. If you want maximum performance, don't paint it. Bottom line. -Ted |
#9 | |
Rotary Masochist
Truth.
_______________________________________________ One stop Haltech, AEM, Syvecs shopping. Installation and tuning. http://www.lms-efi.com Free support. Drop us an email. chris@lms-efi.com 502-515-7482 Facebook @LMS-EFI |
#10 |
Rep Power: 0 ![]() |
Anodizing adds a layer of aluminium oxide (which carries the tint), which is more thermally insulative, although not that bad.
Even if you don't believe established emissivity theory and have no formal physics learning, an anecdote from someone who used controlled conditions may give you a clue. I have a mate who before painting bits in his engine bay experimented with a rubbed back (to remove the red surface finish) bare aluminium coke can and one painted black, filled with water from the same kettle, black one cooled faster, as black body radiation theory would suggest, despite the fact it was covered in paint. I would suggest leaving it bare or a light coat of black. There is a reason copper radiators and OEM steel sumps were always sealed with black paint. Last edited by Slides; 04-14-2014 at 06:52 AM. |
#11 |
Rotary Masochist
I've been up close and personal with a lot of high end race cars and, to the best of my recollection, have never seen a painted radiator in one. The Audi R8 at Mid-Ohio back in 04 comes to mind. Audi has left no stone unturned in their LeMans program. If black was an advantage they would use it. And they don't. The R18 still doesn't use a black radiator. Maybe they haven't thought of doing the Coke can test?
#12 |
Still Building my FD
I thought the black coating originated with copper radiators to keep them looking aesthetically pleasing.
Uh.... hi. |
#13 | ||
I just painted my oil coolers on my R1 FD, thru had copious amounts of red over spray from a less then maco quality paint job, and the red bugged me horrendously...
Will it effect the ability of the exchangers to exchange temperature, I honestly believe it will, do I think that that little bit of paint that on it is going to make enough of a difference even if I had numerous datalogs of before after painting, that a change in temperature could be proven, I highly doubt it, and if it did. Are those few potential degrees difference really going to change how for Most of us, our street cars function? Im confident enough to say no... Sorry for spelling/grammatical errors, phones suck to type short story's on... J.
#14 |
Rep Power: 20 ![]() |
If you do go the cleaning route be careful with pressure washing, the fins will be beat to hell. Purple power is awesome and works very well but don't let it sit on the aluminum long because it will etch the aluminum and leave it looking hazed. If you want to soak it in cleaner use something like simple green.
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
#15 |
Clean S4 Nutswinger
Well, after all the input, I decided not to paint it. I did hit it with some degreaser in conjunction with a power washer, focusing mostly on the end tanks to avoid potentially damaging the fins. It looks better, but will need some detail work with degreaser and a brush.
| Bookmarks |
