Old 04-05-2014, 07:25 AM   #1
t72384
t72384 is on a distinguished road
04 rx8 misfire help!!!
Hey guys im kinda new here but im having high rpm misfires in my 04 rx8. ive read alot of information on the web but still cant figure this out. Ive replaced plugs, plug wires, coils, cleaned the ESS and mass air flow sensor. Its code P0301 front rotor misfire. please someone help
t72384 is offline   Reply With Quote
Old 04-05-2014, 10:40 AM   #2
Dannobre
Have you pulled the plugs to see if they are all firing?
It isn't unheard of to have a coil or wire or plug that is defective out of the box. Use a coil tester to check the coils....
Have you reset the ESS profile? Sometimes you have to do it a couple of times to make sure it takes....
If all of that is OK...then you might want to do a compression check...if you have an apex seal problem that is allowing combustion gases to bypass the seal you can get missfires.....
Other than that...ECU, wiring, power and grounds to coils, wiring to ESS can all cause problems.
You will also have to check the fuel injectors...if one is not firing properly you could have a fuel related missfire
Good luck....
Old 09-04-2014, 09:01 PM   #3
hoosier1104
Dysfunctional Veteran
hoosier1104 is on a distinguished road
After you replaced everything, did you do the 20 brake presses to reset everything?
Freedom is not free. Thank a veteran.
hoosier1104 is offline   Reply With Quote
