Old 03-24-2014, 06:02 PM   #1
jd collector
jd collector is on a distinguished road
two cycle oil
Newby here. My oil metering system doesent seem to be working. I heard that you can mix 2 cycle oil with the gas. If it is true what ratio should I use and should I use high octane gas?
This motor will not be reved much over 4000 rpm. It is installed in a John Deere lawn and garden tractor.
jd collector is offline   Reply With Quote
Old 03-24-2014, 06:42 PM   #2
need RX7
Clean S4 Nutswinger
need RX7's Avatar
TCW-3 oil, around 1oz per gallon is the general consensus.
More info on that tractor!
Old 03-25-2014, 10:36 PM   #3
Depends on the apex seals. If they're stock, than yes, about 128:1 is a good ratio. However, because turbo, I would mix closer to the 100:1 mark, and if you're not using stock apex seals, then it's closer to the 70-80:1 ratio...
Also.... because of the application, I would use more oil as well.
And as stated... please, more info on the trailer.
Old 03-26-2014, 05:33 PM   #4
jd collector
Rotary John Deere
Just finished my rotary powered John Deere. It started as a lawn and garden tractor model 400 with a 20 hp engine. I found a Wankel rotary from a RX2, with a turbo from a Corvair Monza Spyder on it and a Madza tranmission for 50 bucks. I did alot of alterations to the frame to install the Wankel. It has a drive shaft to the JD hydro rear end. High and low range. Lucky for me the motor ran and works fine. It will be shown at tractor shows something like a cruise in.
I have built many tractors with unusual motors, such as snow mobile engines, outboard engines, Geo Metro 3 cyl engines, Yanmar diesels, 36 volt electric, Pontiac 4cy iron duke, Yamaha warrior which was capable of 60 plus mph. and a few others. Heres some pics of Rotary Deere.
Last edited by TitaniumTT; 03-27-2014 at 12:34 AM. Reason: Because I like big pics
Old 03-26-2014, 06:47 PM   #5
WOW, that is cool! I've seen rotaries in airboats, aircraft, go carts, dune buggies/sand rails motorcycles, but that's the first time I've seen one on a lawn tractor
If I had one of those, mowing the lawn would be fun
Old 03-27-2014, 12:37 AM   #6
That is REALLY REALLY cool. I love it... very unique.
However, you're definitely going to need to do something about the oil line. Right now it's run from the front cover directly to the rear iron. The oil is going to overheat in short order especially with the turbo system... props to you for that as well. There are some earlier rotaries that had an oil cooler on the oil filter pedestal. It took coolant to bring the oil temps down. I think that would be the best bet for simplisities sake.
VERY cool project.
Old 03-27-2014, 12:48 AM   #7
chibikougan
chibikougan's Avatar
VERY cool project.
I may have one of the ole 12a under filter coolers I will happily donate. I will look tomorrow.
Old 03-27-2014, 12:54 AM   #8
Cheebs to the rescue!
Old 03-27-2014, 01:01 AM   #9
chibikougan
I also have a passion for the Deere.
Old 03-27-2014, 03:34 PM   #10
wow thats an old engine with twin dizzy! Looks well taken car of. Do you have pics of your build process?
Really interesting exh/intake setup too!
Old 03-28-2014, 01:58 AM   #11
That is so freakin cool.
Old 03-28-2014, 06:14 PM   #12
jd collector
Thanks for the kind words. Im confused about the oil line you are talking about. The only oil hose on the engine goes from near the filter to the turbo and returns to the filler tube. Am I missing something?
Old 03-28-2014, 06:25 PM   #13
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Double post, please delete.
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 03-28-2014, 06:29 PM   #14
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
In the third picture (the one showing the spark plugs) you have a line running along the bottom of the engine from the front cover to the rear iron. That is also an oil line, and the line that Brian (TitaniumTT) is talking about.
Badaas looking project btw
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 03-28-2014, 06:36 PM   #15
He's talking about the line in the picture (spark plug side of the keg) that runs from the engine's front cover to the rear iron. Those 2 oil ports that you have connected together normally go to an oil cooler that sits in front of the radiator in the RX cars. By design, a rotary dissipates about 1/3 of its heat thru the oil. If it runs for any length of time that way, it won't be happy.
