Old 02-09-2014, 09:12 PM   #1
hozzmanrx7
7Club Refugee
hozzmanrx7's Avatar
hozzmanrx7 is on a distinguished road
torque Specs, more than you could ask
ENGINE
SHORT BLOCK
Oil pan bolts 69-95 in-lbs
Tension Bolts 23-29 ft-lbs
Flywheel Nut MT 289-362 ft-lbs , AT Counter Weight nut 289-363 ft-lbs/ Drive plate bolts 32-45 ft-lbs
Eccentric shaft pulley bolt 80-98 ft-lbs
Oil Pump 61-87 in-lbs
Oil Pump gear locknut( the one that sits on top of the gear with the washer with the tab bent) 23-34 ft-lbs
Oil pressure control valve 29-36 ft-lbs
Front cover bolts 12-17 ft-lbs
Oil strainer 61-87 in-lbs
Engine mount on oil pan 46-69 ft-lbs
Left engine Mount 41-59 ft-lbs
Oil regulator value 51-58 ft-lbs
A/C/ and/or P/S bracket M10 Bolt 23-34 ft lbs/ M12 bolt 41-59 ft-lbs
LONG BLOCK
TURBO
Oil Inlet pipe 14-19 ft-lbs
Rats nest bolt 14-19 ft-lbs
Dynamic chamber bracket 14-19 ft-lbs
Water pump 13-20 ft-lbs
Metering Oil Pump 69-95 in-lbs
Exhaust Manifold 23-34 ft-lbs/ Exhaust man. Insulator 69-95 in-lbs
Lower intake manifold 14-19 ft-lbs
Housing/ Manifold Oil nozzle 12-17 ft-lbs
Stock Turbo 33-40 ft-lbs/ Insulators 69-95 in-lbs
Water pipe 17-26 ft-lbs
Air control Valve 69-95 in-lbs
Primary fuel rail 14-19 ft-lbs
Upper intake manifold 14-19 ft-lbs
Secondary fuel rail 14-19 ft-lbs
Throttle body 14-19 ft-lbs
Clutch and Pressure Plate 13-20 ft-lbs
Alternator long bolt 27-38 ft-lbs/ Short bolt 14-19 ft-lbs/ Strap 13-20 ft-lbs
Air pump bracket 14-19 ft-lbs
Air Pump long bolt 12-17 ft-lbs/ Short bolt 17-22 ft-lbs
Crank Angle Sensor 69-95 in-lbs
Stock Oil Pressure Gauge 95-139 in- lbs
Oil Filter pedestal bolts 69-95 in-lbs
Spark Plug 113-156 in-lbs
P/S oil pump 23-34 ft-lbs
P/S pulley 29-36 ft-lbs
Fan Nuts 69-104 in-lbs
Intercooler bolts 69-95 in-lbs
NON- TURBO
Water Pump 13-20 ft-lbs
Fuel Rails 14-19 ft-lbs
Vacuum piping mounting bolts 14-19 ft-lbs
Throttle and Dynamic Chamber 14-19 ft-lbs
Metering Oil Tube 87-122 in-lbs
Intake tube to throttle body 14-19 ft-lbs
OIL SYSTEM
Bolts that hold to body 61-87 in-lbs
Bolts to oil cooler 40-51 ft-lbs
Drain plug 22-30 ft-lbs
Front Oil cooler hose nut 32-40 ft-lbs
Rear Oil cooler hose blot 40-58 ft-lbs
Clamp that holds hose’s together 61-87 in-lbs
CLUTCH COMPANTS
Master to frame nuts 14-19 ft-lbs
Master to hard line 9-16 ft-lbs
Release Cylinder to MT bolts 12-17 ft-lbs
Release Cylinder to soft line 16-20 ft-lbs
Release Cylinder Air bleeder screw 52-78 in-lbs
Clutch Pedal adjustment locknut 8-12 ft-lbs
Hard line to soft line wasn’t in the FSM so if somebody knows what the specs are add it up for others to know
TRANSMISSIONS
MANUAL
Check/fill plugs 18-29 ft-lbs
Drain Plugs A(MAIN one close to engine) 29-43 ft-lbs/ B( TURBO ONLY close to trans mount) 23-34 ft-lbs
Rubber mount 12-17 ft-lbs
Trans mount A(4 Outside bolt) 23-34 ft-lbs/ B(middle nut) 41- 59 ft-lbs
Starter A(bolts)23-34 ft-lbs/ B(nut for wiring) 87-104 in-lbs
Shift lever bolts 69-95 in-lbs
Trans to Engine bolts 27-38 ft-lbs
Cross member for convertible 27-40 ft-lbs
Driveshaft 36-43 ft-lbs
60-69ft/lbs for the flex plate to rear counterweight for light flywheel vehicles and auto cars.
AUTO
Oil pan bolts/bracket 52-69 in-lbs
Vacuum diaphragm bolts 69-95 in-lbs
Oil pipes bolts 17-26 ft-lbs
Bolt/clamp that holds oil pipes together 69-95 in-lbs
Fill/dip stick tube bolts 69-95 in-lbs
Shift lever screws 13-26 in-lbs
Selector lever nut 69-95 in-lbs
Selector cable locknut 7-11 ft-lbs
"he's a tool that moved from being an abusive moderator to a troll that acts like a tool to get his attention now."
John (Jon) Michael Borry = RX7roller02 = skydivr7673 And that's the truth. http://rotarycarclub.com/rotary_foru...t=17659&page=7
hozzmanrx7 is offline   Reply With Quote
Old 01-16-2015, 12:59 PM   #2
Demonsniper1
The cross-eyed kid
Demonsniper1's Avatar
Demonsniper1 is on a distinguished road
Let me just finish posting my list since you left a few parts out with the copy and paste.
AUTO
BRAKES
Brake booster/ power brake unit to frame(4 nuts) 14-19 ft-lbs
Master to brake booster nuts 7-12 ft-lbs
Hard lines to Master 9-16 ft-lbs
Pedal adjustment Locknuts A(In front of pedal) 10-13 ft-lbs/B(behind pedal on rod) 17-25 ft-lbs
FRONT
Caliper bracket bolts 58-72 ft-lbs
Caliper to bracket bolts(bolt that helps rotate up on single pistons) 23-30 ft-lbs
Soft lines to caliper 16-20 ft lbs(single piston)/ 9-16 ft-lbs(4 piston)
Bleeder screw 52-78 in-lbs
REAR
Caliper to bracket bolts (bolt that helps rotate up) 12-17 ft-lbs
Caliper bracket bolts 33-40 ft-lbs
E-brake cable nuts 14-21 ft-lbs
Soft line banjo bolt 16-22 ft-lbs
Parking brake lever bolts 14-19 ft-lb
REAR END/SUSPENSION
Axles to Differential 40-47 ft-lbs
Axles to rear hub 174-231 ft-lbs
Differential fill/drain plugs 29-40 ft-lbs
Differential mounting nuts 54-69 ft-lbs
Shocks Lower bolt 46-69 ft-lbs/ Upper(to body) nuts 17-22 ft-lbs
Subframe nuts 72-87 ft-lbs
Control link bolts(Trailing arm/Subframe) 27-40 ft-lbs
Adjusting bolt and cam plate 46-70 ft-lbs
Lateral link (Trailing arm nut) 22-33 ft-lbs/ (sub frame nut) 33-43 ft-lbs
Sublink bolts 54-69 ft-lbs
Control link(trailing arm/sway bar) 27-40 ft-lbs
Sway bar mounts 27-40 ft-lbs
Front diff mount nuts 65-77 ft-lbs
FRONT SUSPENSION
Lower control Arm (front bolt/nut) 46-69 ft-lbs/ Rear bolts 43-54 ft-lbs
Control link (to arm/bolt) 27-37 ft-lbs/ (to sway bar/nut) 27-40 ft-lbs
Sway Bar mounts 13-20 ft-lbs
Shocks lower bolts 69-86 ft-lbs/ Upper(to body) nuts 22-27 ft-lbs
STEERING SYSTEM
Tie-rod end bolt 22-33 ft-lbs
Tie-rod end Locknut (right after boot) 25-29 ft-lbs
Steering Wheel nut 29-36 ft-lbs
Intermediate Shaft bolts (Upper Bolt) 13-20 ft-lbs/(Lower bolt) 12-17 ft-lbs
Steering Shaft bolts 12-17 ft-lbs
P/S rack mounting bolts 22-33 ft-lbs
OTHERS
Sunroof nuts 5-6.5 ft-lbs
Convertible top motor bolts 23-34 ft-lbs
Convertible top fabric Hook/Bolts 22-31 in-lbs/ Nuts 37-55 in-lbs
Seat bolts 28-38 ft-lbs
Convertible roof panel locks 37-55 in-lbs/ hinges 5.1-7.2 ft-lbs
Demonsniper1 is offline   Reply With Quote
Old 01-16-2015, 03:16 PM   #3
chibikougan
chibikougan's Avatar
Hey guys here are all the torque specs for every part every year every car...Plus the whole FSM... We don't need HC style posts of random info. We have Factory Service Manuals...
Or go to the source.
I like the idea but the info is already put together so well...
http://foxed.ca/index.php?page=rx7manual
