Old 01-30-2014, 10:28 PM   #1
celiguy00
celiguy00 is on a distinguished road
Boost/Vacuum Issues
Ok so I am still new to this FD I got over here in Okinawa Japan. When I purchased the car it would boost to 10 like is suppose to, but now it won't boost past 6. It has an HKS boost controller but it is doing nothing at the moment. I did replace a tube that was broken just under the intakes that was hooked up to the boost controller. Now it makes a weird sound when it comes off boost. After talking to a friend he said it sounds like thats air not being released and it is going back toward the turbo? So my thought is possibly the stock air bypass valve or charge relief valve?
Any thoughts? Thanks
celiguy00 is offline   Reply With Quote
Old 02-01-2014, 01:13 AM   #2
Garfinkles Motor Works
Check for a split in an air hose from the turbo to the intercooler .If the car is mostly stock the curved hose that connects to the intake side of the turbo at the bottom could be split along the seam and is hard to see .I have found this to be the case on several cars in the past .I may have a good one in storage .
Old 02-01-2014, 04:35 AM   #3
celiguy00
hey thanks for the reply. I did find a slice about 1/2" in length that looks like it rubbed on something. So if you do have one in storage it would be shipped to an APO address? Thanks for looking!
Old 02-04-2014, 06:31 PM   #4
celiguy00
Going to try a few junk yards to see if can find a new 90 for the first turbo.
I've read if you unhook the charge relief valve so I can better narrow down the problem with the first turbo not boosting high enough. Is there any more to this?
Next, I have a few pictures of how the boost controller is hooked up and wondering if it "looks" correct? This was all hooked up before i bought the car and curious if any ideas.
Also on the upper intake manifold there are two nipples right next to each other on the turbo/exhaust side. One is going directly to the blow off valve/air bypass valve, and the other is not hooked up to anything. Where is that suppose to be hooked up to? Thank for any help!
Old 02-08-2014, 08:09 PM   #5
celiguy00
Love the response on this site...
Old 02-08-2014, 08:32 PM   #6
chibikougan
chibikougan's Avatar
That's gonna help.
Old 02-09-2014, 01:13 AM   #7
celiguy00
lol yet I still got a response about that post instead of any help or info towards questions i asked? I knew that would be the case though.
Old 02-09-2014, 01:07 PM   #8
chibikougan
Durp!
Old 02-09-2014, 09:57 PM   #9
From your pictures I will say you have a mess from the seller sorry .If I was working on the car I would find some of the diagrams of the simple way to connect everything needed to run the car .Get rid of the things not needed like the fast warm up fast idle parts ect ect . Check all the large needed tubes and connections .Replace all of the small hoses with new ones . Just a roll of 4mm vacuum tubing and about 3 feet of 6 mm tubing.This would be theway I would go about the job .From the pictures I would say the other owner was not a good mechanic.
Old 02-10-2014, 07:44 PM   #10
celiguy00
hey thanks for the response. I will be looking into getting new vacuum tubing, and find the time to tackle this project. While also simplifying the boost controller.
