Old 04-16-2008, 10:57 AM   #1
$100T2
Big Daddy
$100T2's Avatar
Let's talk remote mounted turbos...
Has anyone ever thought of doing this with an NA? I know that it would be far easier to plumb in a remote mounted turbo than to do what other guys (you know who) did...
As far as I know, you need a turbo, an oil cooler and line for it and a pump, unless you somehow plan on running it to the engine oil. Let's discuss the logistics, come up with a plan, and then someone, probably me, will be the guinea pig to try it out.
Problem solving time, people. Let's rock!
Old 04-16-2008, 11:00 AM   #2
Relocate it to a storage bin?
For real though, I like where this is going. Hopefully there will be some good info put in here.
Old 04-16-2008, 11:29 AM   #3
$100T2
Big Daddy
$100T2's Avatar
Actually, that's not a bad idea. If you cut out the storage bin and weld in a box, reversing it so instead of open to the car, it's open to the undercarriage, that would give you a lot of room. Take out the passenger bin, and the turbo would be conveniently located, too.
Old 04-16-2008, 11:31 AM   #4
Damn I'm good. Could you duct pipes/air for an intercooler back there?
Old 04-16-2008, 11:35 AM   #5
$100T2
Big Daddy
$100T2's Avatar
Now you're pushing it.
Old 04-16-2008, 11:41 AM   #6
Small intercooler? With alky or water injection?
Old 04-16-2008, 11:47 AM   #7
I always thought one of the advantages of remote mounting is the long charge tubes serve as intercoolers themselves
Old 04-16-2008, 11:49 AM   #8
So a small intercooler would be good...
Old 04-16-2008, 11:50 AM   #9
^ Maybe a modified TII top mount?
Old 04-16-2008, 12:00 PM   #10
$100T2
Big Daddy
$100T2's Avatar
If you put some cooling fins on the charge pipe, it could be one long intercooler. Drawback: Road debris. Maybe run the charge pipe inside a larger pipe with directed airflow through it to surround the charge pipe?
Old 04-16-2008, 12:31 PM   #11
Good luck finding a place under the FC to remote mount a turbo. You can put one where one of the mufflers sit, but that would mean a lot of long tubing. You could put one in the front bumper somehow, and melt the front end to the ground.
Just another note. The stock turbo is too puny to deal with a big FMIC, much less all the tubing RMing it would create. What turbo would you remote mount, that would fit, and not lag like hell?
Old 04-16-2008, 01:50 PM   #12
$100T2
Big Daddy
$100T2's Avatar
Which is the point of this thread. We're going to do all the theoretical stuff now and work it out, then try it.
Old 04-16-2008, 03:27 PM   #13
Rotary_Rocket_87
2nd Generation Freak
Rotary_Rocket_87's Avatar
Rotary_Rocket_87 is on a distinguished road
STS Turbos makes remote kits for alot of vehicles. They could probably figure this out with little difficulty.
'87 TII- full emissions removal, a/c removed, FPD removed, dual 12" e-fans, Rotary Performance FCD, ACT unsprung 6 puck w/ Xtreme PP, custom open 2.5 inch exhaust, custom clutch pivot ball, K&N cone filter, TB mod, RB downpipe, motor blown 8/7/09
'94 Mazda B4000- POS beater truck, stock
"The easiest way to fail is to never try." - Me
Rotary_Rocket_87 is offline   Reply With Quote
Old 04-16-2008, 03:53 PM   #14
^True, but I think he is wanting to go low budget on it
Old 04-16-2008, 07:23 PM   #15
$100T2
Big Daddy
$100T2's Avatar
What's the fun in that? Plus, if we figure it out and do a how-to thread on it, other people can duplicate it.
