Closed Thread
Old 11-12-2013, 10:09 AM   #1
Homer
Homer is on a distinguished road
Diff help
Wot is the lowest diff ratio I can get for my rx8
Homer is offline
Old 11-12-2013, 10:48 AM   #2
Kman Art
The Converted
Kman Art's Avatar
Kman Art is on a distinguished road
What year model is your RX8? It either came with the 4.44:1 or 4.78:1 final drive. Models built 2008 or newer came with the shorter R&P.
Kman Art is offline
Old 11-12-2013, 11:14 AM   #3
Homer
I need down in the 3. Something ratio mine is a 54 plate so it's a 4.444
Homer is offline
Old 11-12-2013, 11:37 AM   #4
Kman Art
The Converted
Kman Art's Avatar
You could source a '93+FD diff, They came with 4.10:1, but not anything from '99+FD as they came with 4.30:1. After that, it's aftermarket.
Why would you want such a long final drive?
I have a JDM FD and can't stand how long my gears are with the 4.10:1. Just installed the '04 RX8 4.44:1 but haven't driven the vehicle yet to see the difference.
Kman Art is offline
Old 11-12-2013, 12:03 PM   #5
Auto 93+ FD came with a 3.9 diff IIRC.
I believe i've seen it used in Rx-8 before, especially ones with LS1 swaps that use transmissions that would make better use of a 3.9 gear. Can't confirm which generation 8 diff was used though.
FerociousP is offline
Old 11-12-2013, 03:14 PM   #6
Homer
Need to be down to 3.445 or 3.9 might work where could I find one thanks I need lower revs and if there anyway Thst would stock new parts
Homer is offline
Old 11-12-2013, 08:26 PM   #7
I don't know why this thread was reported to the moderators, but...
To the OP:
You do not give enough information WHY you want to drop the rear diff ratio.
People have already asked you if this is a V8 swap, but you do not even answer that question.
If this IS NOT AN ENGINE swap, I'm not sure what you're trying to do.
Dropping the rear diff ratio ON A STOCK ENGINE RX-8 IS A STUPID IDEA.
If you're are trying to conserve gas mileage, you're going to end up with a slug of a car.
Lowering (numerically) the rear diff ratio will significantly affect the acceleration of your vehicle.
If you're fine with that, you're better off getting rid of the RX-8 and buying a Fiat 500.
I doubt this is some crazy 20B swap...
If you have resources to do something like this, you shouldn't be asking us how to find such parts.
Please use the REPORT icon to report INFRACTIONS - not because you're not getting the answers you want.
RETed is offline
Old 11-13-2013, 03:52 AM   #8
Homer
No one ask wot I'm doing people have hinted why I won't to drop so far I have a Diesel engine in car running about 350 bhp at min with poss off going up higher but it revs are to hight I'm not saying to much cost hope to make a kit out off it
Homer is offline
Old 11-13-2013, 10:25 AM   #9
Kman Art
The Converted
Kman Art's Avatar
Ok, my eyebrows just went way up!
You have a diesel engine in your RX7???
If you want to find something below 3.9:1, I would suggest changing your rear end to a Ford IRS setup with the 8.8" rear. Gears are available from all over the place. It is an expensive swap, so I would probably search around for more RX7 gear options.
Kman Art is offline
Old 11-13-2013, 03:06 PM   #10
Homer
Rx8 diesel
Homer is offline
Old 11-13-2013, 04:38 PM   #11
http://www.mazdatrix.com/8-Diff.htm
^notice the 3.909 gear.
http://www.mazdatrix.com/getprice.as...m=27-110A-P062
^notice it says 93-95 + Rx-8. (says this for all ratios actually).
http://www.mazdatrix.com/g5.htm
^Notice at the bottom. 93-95 AUTOMATIC has 3.909.
Now that I think about it, I sold a Rx-8 R&P to a FD guy who wanted a high number gear. So there ya go.
Obviously, cheap option would be to find an auto FD used diff, and swap in ring and pinion. New, especially from mazdatrix, will be quite spendy.
Old 11-13-2013, 05:07 PM   #12
Homer
Thanks for help I'm going to look for a rear diff out off a auto rx7 then thanks hope it's low enough for me ?
Homer is offline
Old 11-13-2013, 05:13 PM   #13
Homer
If I find a diff how will I no wot ratio it is I counted my diff I got 40 teeth on crown and 9 on pinion so wot would a 3. 9 diff be thanks
Homer is offline
Old 11-14-2013, 04:36 AM   #14
Mitchocalypse
Mitchocalypse's Avatar
dude.. lets assume english isn't your first language (and for that matter, hope it isn't).
We can forgive the odd spelling mistake, but even if this is your 5th language, you can't possibly think your punctuation is even remotely correct. I don't even understand what your question is because I just can't make sense of what you're saying.
And for future reference,
wot = what, unless you are trying to convey the term "Wide Open Throttle."
there is a difference between "no" and "know."
Also, I'm not being a grammar nazi here either. There is a big difference between that and just asking you to post something that a reader can make sense of.
Mitchocalypse is offline
Old 11-14-2013, 08:15 AM   #15
Homer
It a club not a spelling test and I'm use ing my phone predictive tex and thanks a lot for slagging me off what a good person you are
Trying to find out if I buy a diff wot amount off teeth would be on the crown and pinion gear how hard was that Mitch
And I am English born and bread ????
Homer is offline
Closed Thread
