Old 11-11-2013, 04:33 PM   #1
N326 ecu. Black/Blue wire? Pin 3B
87 N326 ecu and engine harness in GSLSE
black and blue wire, pin 3B on the ecu. does this need to go to anything particular? wiring diagram says it goes to the circuit opening relay but not sure how to incorporate that with the GSLSE stuff. Can i ground it out?
tracking down reasons for the engine not to start.
Old 11-12-2013, 07:13 AM   #2
88turboii
destroy, rebuild, repeat
88turboii's Avatar
3B is the 12V starter input signal for the ECU, it lets the ecu know you are trying to start the engine. im not exactly sure how it works, but the ecu may use this to use a priming fuel map instead of the base map. could be the reason your not starting
im not familiar with FB's, but you could wire it into the same wire that goes to the starter solenoid
Old 11-12-2013, 01:18 PM   #3
mazpower
Rawr Bearclaw
mazpower's Avatar
mazpower will become famous soon enough
Hook it to the ignition switch so it's supplied with 12 volts only on Start. It does richen up the mixture on start up. We've cut this wire before when dealing with flooding issues on start up and it helped. The car still starts fine with it unhooked, at least in mild weather.
Illicit Performance
Rotary building, porting, tuning, chassis dyno services
www.illicitperformance.com
mazpower is offline   Reply With Quote
Old 11-12-2013, 06:35 PM   #4
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
it differentiates between the AFM signal and the basic cranking injection maps. i would hook it up unless the engine is having flooding issues after initial startup, in fact disconnecting it is just a bandaid for more serious problems.
http://rotaryevolution.net
Old 11-12-2013, 08:47 PM   #5
we had an issue with an S5 n/a swapped Miata that wouldn't always start, reconnected that wire and she banged off every time.
