Old 10-31-2013, 08:42 PM   #1
calicrewchief
Rotary Tuner in Training
calicrewchief's Avatar
calicrewchief is on a distinguished road
Should I use or loose this iron?
I just bought this from someone and immediately regretted my decision. If I did choose to use it, will I see a significant lose of compression or even worse damage to the corner seal?
calicrewchief is offline   Reply With Quote
Old 11-01-2013, 02:32 AM   #2
BadTPS
BadTPS is on a distinguished road
Wow that sucks man. that looks unusable. I know how you feel I recently bought a rotor that was dropped during shipping.
BadTPS is offline   Reply With Quote
Old 11-01-2013, 06:37 AM   #3
infernosg
IT'S ALIVE!
infernosg's Avatar
Pretty big dirtbag of a seller to knowingly sell a bad iron. I wouldn't use it. What iron/engine is this?
Old 11-01-2013, 08:59 AM   #4
calicrewchief
Allegedly part of a Ortiz racing block that blew a seal. I guess they let it sit for way too long and good ole corrosion occurred. It's a !3BRE iron. I was trying to avoid buying a brand new one and after searching for a while I finally found this one.
Old 11-01-2013, 11:03 AM   #5
the spyder
the spyder is on a distinguished road
Local? And I think I know where one is, front/rear/middle? A friend is selling his track FD in the spring and has 2-6 motors around his shop. At least two are 13bre.
*Does that look re-ground and poorly recoated to anyone else?
the spyder is offline   Reply With Quote
Old 11-01-2013, 11:17 AM   #6
calicrewchief
To me it looks like pitting corrosion from coolant that occurred prior to lapping.
It's from a fella in WA. We've resolved the issue in a respectable manner.
Old 11-01-2013, 02:00 PM   #7
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
yeah i wouldn't use it, doesn't appear to have been re-nitrided and the amount of material removed is probably already beyond spec.
i doubt it would harm compression or the seals however but everything combined is just too risky. looks like typical rust from water sitting in an engine for a year or longer.
http://rotaryevolution.net
