Old 10-20-2013, 04:58 AM   #1
bowjangles
bowjangles is on a distinguished road
vacuum hoses on '76-'78 13-B
The 13-B in my Tr-7 idles much smoother with the vacuum hoses (tubes) that run from the distributor to the carb base DISCONNECTED.
Is it O.K. to run the car this way- does this indicate a problem? If so, can it be corrected? Thanx
bowjangles is offline   Reply With Quote
Old 10-22-2013, 07:39 PM   #2
surem
surem is on a distinguished road
Yes u can use it with out it.. That vacuum is their to speed up the timing when ur going faster...
surem is offline   Reply With Quote
Old 10-23-2013, 03:23 AM   #3
bowjangles
thanks for the info Surem
