Old 10-06-2013, 05:56 PM   #1
WankelsRevenge
WankelsRevenge's Avatar
Checking clutch arm/pressure plate
So after messing around with my entire clutch hydrolic system the past couple weeks, Ive come to the conclusion that everything is in proper working order. I had a friend over helping me try to figure things out, and he mentioned it could possibily be that either my clutch arm has something wrong with it, or possibily even my pressure plate is bad. Is there any simple way to check these things without dropping my transmission, or do I have to pull everything out to check on it?
Summary of this thread:
Old 10-06-2013, 06:01 PM   #2
JL1RX7
The clutch fork which the throw-out bearing rides on can be checked by removing the slave and if it moves freely back and forth you are good. Make sure the slave piston arm is sitting correctly in the fork when you re-install.
With the pressure plate I could only think does it slip? No crazy noises etc?
Old 10-06-2013, 06:12 PM   #3
WankelsRevenge
Well I check tonight and the piston on the slave is seated right, its pushing the arm in, but Im not getting any engagement on the clutch, nor is it returning at all. My clutch still has plenty of grab as I can start the car with it in 1st, and shift gears without using the clutch if I have to absolutly drive it somewhere. Im looking at replacing my trans/clutch/flywheel in the future, just dont want to have to drop the whole thing before hand if I dont need to
Old 10-06-2013, 06:19 PM   #4
JL1RX7
Yea check it is seated right first. If it is slightly off then you wouldn't get the push/return like you should.
How many miles on the clutch?
Old 10-06-2013, 06:31 PM   #5
WankelsRevenge
Im not sure, I know the engine was rebuilt recently, but not if they replaced the clutch and everything when they did the rebuild. As for the slave piston is was right in place where it should be.
Old 10-06-2013, 06:56 PM   #6
JL1RX7
Possible the throw-out bearing slipped off the fork? Don't think it would be possible kitted up. But never know.
When you push the peddle in getting full stroke on the slave.(Yes I know that could be taken the wrong way)
Old 10-06-2013, 07:40 PM   #7
WankelsRevenge
I believe so, Its deffinatly pushing against the clutch arm. The main issue seems to be the clutch isnt disengaging now is the pedal coming back up at all. I guess in the next few days I might see if I can get it up on jack stands and drop the trans and see what I find. Any tips on how I can see if the pressure plate is shot?
Old 10-06-2013, 10:23 PM   #8
ElTeeFauci
Tuned by... ME!
ElTeeFauci's Avatar
ElTeeFauci is on a distinguished road
The clutch pedal should get its return force from the action of the pressure plate fingers (which are essentially springs) pushing back on the throwout bearing, which pushes on the fork, which forces the slave back in, forcing the fluid into the master cylinder's piston, and finally pushing the clutch pedal back out. (I think anyway)
Gonna need more than a 17mm wrench this time son!
So you've actually seen the slave pop out when someone else hit the clutch pedal? Tried holding the master in with your thumb or something while someone hit the clutch?
Its a big sh!t sandwich... and we're all gonna have to take a bite...
ElTeeFauci is offline   Reply With Quote
Old 10-06-2013, 11:03 PM   #9
WankelsRevenge
Yes to both, I pushed the slave piston in and then pressed down on the clutch, the low and behold the slave piston was pushed back out again. I also disconnected the hardline from the master and tried covering the whole with my thumb while someone pumped the pedal and I could feel the suction on it. Everything in the hydraulic system seems to be operating perfectly, which is why I think the problem lies elsewhere.
Old 10-06-2013, 11:17 PM   #10
ElTeeFauci
Tuned by... ME!
ElTeeFauci's Avatar
So when you pushed the slave piston back in, was it bolted to the transmission at that point?
What I'm wondering is if you put your thumb in between the slave and the fork, how much pressure would you really feel? If there is air in the line... not much. But probably enough to move the slave if it wasn't pushing on anything (if it wasn't bolted to the tranny).
Old 10-07-2013, 06:32 AM   #11
WankelsRevenge
Yeah its already bolted down. If I hold my finger between the piston and the fork its not gonna crush my finger will it?
Old 10-07-2013, 08:56 AM   #12
ElTeeFauci
Tuned by... ME!
ElTeeFauci's Avatar
Well don't push the pedal TOO hard.... Lol. You'll know.
Old 10-09-2013, 07:32 AM   #13
Garfinkles Motor Works
Do not put your finger in there and have someone push ,very bad idea . Re build the master and slave cylinders and bleed them then try the clutch while you have all your fingers .
Old 10-09-2013, 10:11 AM   #14
ElTeeFauci
Tuned by... ME!
ElTeeFauci's Avatar
Yeah... rebuild the brand new slave. Thats a better idea.
Nobody is saying put your finger in there and SMASH the clutch pedal...
Old 10-21-2013, 05:33 PM   #15
WankelsRevenge
Well I got the new slave and master installed, but still have the same problem. I can move the clutch fork back and forth pretty eaisly. Im at a loss at where to go from here. I dont think its the pressure plate because I can start the car with it in 1st and drive it by shifting without the clutch if I have to. In all actuality what are the chances eithe rthe throw out bearing has slipped off the fork, or that the fork slipped off the piviot ball?
