Old 08-27-2013, 03:27 PM   #1
jimstaz
jimstaz's Avatar
jimstaz is on a distinguished road
Why is there coolant on sparkplugs?
why do o have coolant on my spark plugs.. the car idles fine... is somehting going wrong with the engine is is the coolant normal? just doing a tune up... and recently did replace the radiator about a month ago.
jimstaz is offline   Reply With Quote
Old 08-27-2013, 07:08 PM   #2
mazpower
Rawr Bearclaw
mazpower's Avatar
mazpower will become famous soon enough
Coolant on spark plugs means the seals have failed and it's time for a rebuild.
Illicit Performance
Rotary building, porting, tuning, chassis dyno services
www.illicitperformance.com
mazpower is offline   Reply With Quote
Old 08-28-2013, 06:32 AM   #3
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
You have an internal coolant leak for sure. You can try the AlumaSeal in the coolant. I've had
success with it on a leak between the front plate and the front housing at the top. It took
a few days but now the leaks is pretty much gone. Some folks have done this and kept a
motor running for over 50K longer.
Of course this was on an old 12A and not an rx8. YMMV.
