Old 08-10-2013, 01:47 PM   #1
MRmanDUDE11
MRmanDUDE11 is on a distinguished road
Zoom Power Engine Cleaner
So I believe my RX-8 has a carbon build up and a friend of mine, who was a Mazda mechanic gave me his bottle of Zoom Power Engine Cleaner. He gave me the jist of how to use it and the instructions are on the bottle. But Some of the things I have no idea what it is talking about. I was hoping some of you guys could help me out with this? Pictures would be nice.
MRmanDUDE11 is offline   Reply With Quote
Old 08-10-2013, 05:43 PM   #2
JL1RX7
Not to push you away from this site but RX8 club has some great stickies on this. I still need to do this but it is pretty simple.
Need two people for the starting and pouring aspect but that's about it. Just hook up the cleaner to one of the vacuum nipples and squirt away.
If you are feeling frisky take some pics and start the sticky here.
Old 08-11-2013, 08:51 AM   #3
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Why not just use demineralized (distilled) water to clean the engine?
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 08-11-2013, 09:00 AM   #4
JL1RX7
Mazda has a "special" cleaner that they made for the eight. It is the same thing as seafoam. It is supposed to work better and break the carbon up better. One of these weekend's I need to do this to both of my cars.
Old 08-11-2013, 09:44 AM   #5
Raksj04
I have Ultra power in me.
Raksj04's Avatar
I poured seafoam into my gas tank and a week later I lost an APEX seal. in my N/A FC Not sure if there is a cause and effect to that or not or if it was just time for the motor to good.
Old 08-13-2013, 01:56 PM   #6
Sephitrask
BOILED PEANUTS!!!
Sephitrask's Avatar
Sephitrask is on a distinguished road
you put it in your gas, which basically was stripping the oil from the rotor housings, which is why you went boom.
The method here is to hook a hose up to the nipples on the LIM, put the other end in the bottle of seafoam/cleaner. then go in the car, hold the gas peddle to the floor (built in fuel cut in the rx8) and crank for 10 seconds. do that for each of the housings. let soak for at least an hour. do the same process with some two stroke after, then start it back up. be prepared for a lot of smoke as the seafoam and two stroke burns off. I honestly don't know how much this really works though, IMO the water is better...
www.rotarycarclub.com
"The way a Rotary engine makes power is ferocious, much like having a chainsaw under your right foot."
Sephitrask is offline   Reply With Quote
Old 08-17-2013, 06:17 AM   #7
doghouse
doghouse is on a distinguished road
where can i get a bottle to buy?
doghouse is offline   Reply With Quote
Old 08-17-2013, 09:43 AM   #8
JL1RX7
Seafoam at any autoparts store. Distilled water at Wally World.
Old 08-28-2013, 01:06 AM   #9
MRmanDUDE11
UPDATE:
I actually found what the problem was. One of the spark plug wires was off the plugs. I found this out right after new plugs and coils arrived. Good news is it was an easy fix and i have spare parts! And I was also given a complimentary empty bottle of the Zoom Engine power cleaner....but now I know how to use that or seafoam. Thanks for the help anyways guys!
Also check out WNCrides.com
'05 RX-8 Renesis 13B
