Old 08-06-2013, 07:58 AM   #1
Mitchocalypse
Mitchocalypse's Avatar
Studs vs. bolts for mounting turbo
Is there a preffered way to mount a turbo to a manifold?
Or does it make any difference?
Old 08-06-2013, 08:56 AM   #2
JL1RX7
I wouldn't think so. Setting the right torque with either one is more important than anything else. That should keep it from leaking.
Old 08-06-2013, 10:28 AM   #3
RXtacy
RXtacy's Avatar
You want to use studs/nuts. Getting a bolt/nut on would be quite a pain for most manifolds.
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 08-06-2013, 04:26 PM   #4
88turboii
destroy, rebuild, repeat
88turboii's Avatar
studs. bolts eventually wear out the threads in the manifold flange and could end up cross threading. you can always replace a stud if it gets buggered up. same reason why there are studs in the housings
