Old 07-12-2013, 12:01 PM   #1
Mannykiller
Mannykiller is on a distinguished road
Virtual Works Upper Intake Manifold/Throttle Body set up
Up for sale is a one off Custom Upper Intake Manifold made by Virtual Works. This beautiful Intake manifold is all Aluminum. Mating surface of the flange that connects to the Lower intake Manifold has been machined perfectly flat for a perfect seal. Comes with Gold heat reflective tape covering the underside of all four runners, Ports for Vac, tapped hole for triumph Fast Acting Air Intake Temp sensor (Fits OEM Sensor as well) With the Manifold Comes an Edelbrock 75 MM Throttle body and TPS that work flawlessly. This throttle body has made 860 WHP on a friends EVO. THrottle Body was tapped for Water/Methanol Injection nozzle but can be plugged easily.
Price for whole set up including Throttle body is $1350 Shipped
Please call or text me for quicker response
661-five one zero - seven 9 four 9
Thanks!
Pics
Here is a Pic of the Manifold... CHarge TUbe and 90MM throttle Body NOT included
FPR Mount Modified for more clearance
set up on my car
Underside Gold Reflective
Bends
Pic of beautifully blended runner ports inside the manifold
Edelbrock 75mm Throttle Body and TPS
Mannykiller is offline   Reply With Quote
Old 08-19-2013, 03:15 PM   #2
Mannykiller
Sold
