Old 06-30-2013, 10:20 PM   #1
Car dying when hot ambient (but engine temp is good)
was 103 today. We were driving the renesis FB up bogus basin road in idaho (so climbing elevation) but not too hard. The car just died. Wouldnt start back over. temp on gauge was good, but we had to let it cool down to start again. even the fuel tank was hot to the touch.
could it have vapor locked? is there a common symptom with this in normal Rx8s? the ecu and electronics are the same. Fuel system is obviously slightly different.
Old 07-01-2013, 02:14 PM   #2
RX200013B
RX200013B's Avatar
RX200013B is on a distinguished road
sounds like vapor lock to me..
ULTIMATE N/A
RX200013B is offline   Reply With Quote
Old 07-01-2013, 03:34 PM   #3
Never had that happen in the RX8. Haven't reached extreme altitudes though, but have run it hard during track days at over 100* ambient and 110*+ surface temps...
What is being used to monitor the engine, anything? Any kind of datalog for it? It does sound fuel related though...
Old 07-01-2013, 04:07 PM   #4
the stock gauge cluster is being used.
Old 07-01-2013, 04:15 PM   #5
JL1RX7
I would get something besides the stock cluster. You can use the CANBUS to read all the engine sensors if you have a translator and output device. With the stock cluster you have three settings for the temp gauge. Off, normal and new engine. Oil pressure is off and like 5 psi. So they are this side of useless.
Old 07-02-2013, 06:24 PM   #6
rotar bones
rotary owner/driver.
rotar bones is an unknown quantity at this point
I am in Denver and I run the mountain roads at 11,000 feet, have never herd of that one. The suggestion about gauges is a good one. Digital oil and coolant temp gauges are the best. Summit racing has several at fair prices well as I gage rack for them.
Please come back with the fix and share. That is really interesting Bro.
rotar bones is offline   Reply With Quote
