Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Suruga Performance Co., Ltd
Suruga Performance Co., Ltd www.suruga-performance.com (Japan) JDM parts exporter
Old 04-11-2013, 01:25 AM   #1
Suruga Performance
Suruga Performance is on a distinguished road
Defi new products
Here is two new prducts from Defi for the first time on sale at Suruga Performance !
First, the Defi Smart Adapter.
You can connect it to your car OBD-II connector and receive all the data on yourl Androïd device via Bluetooth.
But you can also connect it on the Defi Advance Control Unit and once again receive all the data from the connected sensor on your Androïd.
And with the different Apps available on Google Play you can display, record and analyse all the data.
In the case of use with the Advance System, it can be connected after the meters already installed, or directly on the 'Advance Control Unit and in that case you don't need meters at all !
And, big exclusivity, the Advance C2 meters ! They will be officially released only in June, but they are already available at Suruga Performance.
Available in 2 colours : blue or pink.
Diameter : 60mm
Display : boost, intake manifold pressure, oil pressure, fuel pressure, oil temperature, water temperatre, Exhaust temperature
Plugs on the Defi Advance Control Unit. Possibility to connect up to 7 meters
Everything is available on our website here and here
And little news on the website, you can change the currency to have an idea of the day change. It will be fully operationnal within 2-3 days.
SURUGA PERFORMANCE
All your parts direct from Japan
http://www.suruga-performance.com
Suruga Performance is offline   Reply With Quote
