Old 04-07-2013, 06:56 PM   #1
WankelsRevenge
WankelsRevenge's Avatar
Transmission Options?
So Im having quite a few problems finding a transmission to swap into my 86 NA, which has got me wondering what other options might be feasible. Im mostly curious about what options are out there and are recommended without needing a ton of modifications to get everything to work. Also if anyone has any odd setups they like and would want to share.
Summary of this thread:
Old 04-07-2013, 07:00 PM   #2
What are you trying to accomplish by doing the transmission swap?
Old 04-07-2013, 07:05 PM   #3
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
+1
power goals and intended use are quite important.
easiest and cheapest of course being just stock and turbo components.
http://rotaryevolution.net
Old 04-07-2013, 07:11 PM   #4
WankelsRevenge
Well right now my 2nd and 3rd gear schrynos are on their way out, so a transmission swap will be needed eventually. Sadly Im having problems finding a S4 NA one and was just curious what my other options were without having to do any huge modifications.
Old 04-07-2013, 07:18 PM   #5
Rotary Evolution
rotaryevolution.net
depends on what you mean by huge. but if it's a stock car then just keep looking for a used transmission. you can use a series 5 n/a transmission as well but you will need the crossmember with it from a series 5 car. the rest is all bolt in with no difference.
an FC turbo II transmission will also work but will be a bit spendy since you need the transmission, starter, crossmember, clutch, flywheel, throwout bearing, slave cylinder and a modified driveshaft or ream out the holes in the diff flange with a stock turbo driveshaft.
most anything else would either need an adapter plate with all the above and/or transmission input shaft modification.
you could also just look into having it rebuilt, which usually runs about $600 for the n/a transmission.
Old 04-07-2013, 07:44 PM   #6
I run a 6-spd in my FC.... it bolted to the engine
Old 04-07-2013, 07:58 PM   #7
WankelsRevenge
Haha, a 6speed out of?????
Old 04-07-2013, 08:03 PM   #8
Rotary Evolution
rotaryevolution.net
an RX8, which requires about as much work as the TII transmission which is still more durable, and likely more expensive unless you get lucky. the RX8 also requires a fabricated transmission mount since it uses a power plant frame.
Old 04-07-2013, 08:05 PM   #9
Clearly you don't know about what I've done to this particular transmission to make it fit, work, and stand up behind ~400rwhp and repeated track days..... onto my favorite question,.....
What makes you think the RX8 transmission is weak?
Old 04-07-2013, 08:07 PM   #10
Rotary Evolution
rotaryevolution.net
because i know of owners who have repeatedly broken them behind n/a renesis engines.
Old 04-07-2013, 08:26 PM   #11
Define broken.
Old 04-07-2013, 10:32 PM   #12
Old 04-07-2013, 10:49 PM   #13
i was able to use FB transmissions, but i think i either 1. changed the tail housing (somewhat easier) or just fudge one of the transmission mounts some.
Old 04-07-2013, 10:50 PM   #14
id like myself some RX8 transmissions. friend has two he would sell me. then i need to talk about fixing them.. (2nd gear is pooped, as you would expect)
Old 04-07-2013, 11:07 PM   #15
because it's weak...... right?
