Old 04-04-2013, 12:26 PM   #1
ran83
ran83 is on a distinguished road
fuel injection conversion
has any one here of a fuel injection conversion for an 83 12a motor. Here is what got me to thinking....... i tried to see if there were any cold air systems for the caburated motor and all i can come up with is the muscle car style air cleaners. i have seen where people with mad skill have made their own air box with some welding and fabrication but not really what im looking for. any ideas?????
ran83 is offline   Reply With Quote
Old 04-04-2013, 12:35 PM   #2
infernosg
IT'S ALIVE!
infernosg's Avatar
There are plenty of aftermarket Weber and Holley-styled intake manifolds for the 12A. You could always pick up one of those and get one of the many throttle body setups out there that are made in Weber and Holley carb styles. That's the easy part. The hard part is redoing the fuel system for a high pressure setup and control system for the injectors. You'd still have to make some kind of cold air box though.
Old 04-04-2013, 12:40 PM   #3
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
pro-jay makes some clean looking TBI's but at the end of the day it is:
a: unecessarily large for a stock 12a
and
b: still throttle body injection
http://www.pro-jay.com/Throttle-Bodies_c9.htm
http://rotaryevolution.net
Old 04-04-2013, 01:02 PM   #4
ran83
yeah figured thats what i would get i guess it would be better to go with a 13B and go from there
Old 04-04-2013, 01:30 PM   #5
infernosg
IT'S ALIVE!
infernosg's Avatar
I think there are some 45 mm DCOE-style throttle bodies out there, which would be fine for a stock 12A. There wouldn't be much benefit over an actual DCOE carb setup though other than better fuel atomization and control. For the overall cost you'd be better off finding a fuel injected 13B and swapping that.
Old 04-04-2013, 01:32 PM   #6
ran83
INFRONOS I am gonna have to agree a 13b is gonna be my best bet and not only that every thing is alot cheaper
Old 04-04-2013, 01:50 PM   #7
Rotary Evolution
rotaryevolution.net
assuming you can find a reasonably priced complete swap. some external engine work is needed but it isn't all that bad. wiring everything up is going to be the most difficult part of the project.
Old 04-04-2013, 02:04 PM   #8
ran83
yeah i hear that there are painless wiring harnesses out there so i will certainly do my research in depth before jumping into anything
Old 04-04-2013, 05:55 PM   #9
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
If you go with the fuel injected 13B the easiest way is to run an aftermarket ECU, HalTech, etc. Wiring it all up would be much easier than trying to use the stock ECU. They can be pricey, but if you plan on playing with the engine very much you're going to need one eventually.
Old 04-04-2013, 06:04 PM   #10
RICE RACING
Don Mega
RICE RACING's Avatar
What he said,
I have a student here who is building up a motor as part of his training and he is running it with Weber style IDA induction (due to restrictive gay laws for young people when they first get their licence!).
He has done it expe3nsive though with a Motec M600 and 13B-REW street port, the application is the same though to your 12A.
A simple conversion can be done using all late model 13B-REW or Cosmo intake system and fuel lines, injectors etc with a simple adaptor plate to the motor. Seen this set up (will host video on my site) of a 160+mph 8 second RX3, when I was consulting for them and supply exploding ceramic apex seals LOL.
There are many ways you can do it.
Probably the adaptor plate is best.
Seen this in a speedway car running NA 13B-REW intake, and cheap Haltech ECU, all you need is a lift pump, surge tank and high pressure pump, adapotor and 13B Turbo intake system and away you go. The Speedway engine 13B made 280bhp 'bridge ported' on the engine dyno so those intakes are not restrictive at all.
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 04-04-2013, 06:06 PM   #11
RICE RACING
Don Mega
Even better
Only stay 12A if you have a point to prove etc. Otherwise 13B all the way and later model EFI turbo set up
9.0:1 comp runs great NA
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 04-05-2013, 11:01 AM   #12
ran83
yeh i dont even like the carb/throttle body look wanting to make it a bit more sleek so to speak
Old 04-05-2013, 11:02 AM   #13
ran83
looking forward to seeing GySgt's 7 and see how he did things
Old 04-05-2013, 11:30 AM   #14
GySgtFrank
GySgtFrank's Avatar
I stayed as close to stock Mazda FC engineering as I could. Nothing fancy, some of these others projects put me to shame. Which is why I suggested going with the stand alone right away. I'm what Rice likes to term one of those broke ass c***s. So I had to do it the hard way.
Old 04-05-2013, 12:07 PM   #15
ran83
lol i no shame in the game man it gets the job done! i am just looking for a little more umph out of what i have
