Old 03-21-2013, 10:36 PM   #1
WankelsRevenge
WankelsRevenge's Avatar
Starting engine while flooded
Im having an issue with my engine flooding if I dont start it and let it run for a bit once a day or so. The bad part is I have to be to work in the morning and nothing I do can seem to fix the problem this time. Ive been told my multiple people to pull fuses and crank the engine for a bit to get all the excess fuel out, the problem is Im being told to pull diffrent fuses by diffrent people. Some say the two under the hood (engine comp, and engine ign I think) and another says to pull one out of the fuse block inside the car. Does anyone know which of these should work, or if any of them will?
Summary of this thread:
Old 03-21-2013, 11:00 PM   #2
FDguy
No need for 5.0L
FDguy is on a distinguished road
Doesn't answer your questions but I usually pull the plugs out and crank it with the fuel pump fuse out.
Another thing I do is a hold the gas pedal to the floor and crank a few times. Now this is on an FD I don't if this will work on the FC
FDguy is offline   Reply With Quote
Old 03-21-2013, 11:24 PM   #3
Pull BOTH the "EGI" and "BTN" fuses.
What these does is kill power to the stock ECU and coils.
If you pull just the EGI fuse, there's a 50 / 50 chance the rear coils will stop firing and reward you with a dead tach.
Annoying.
When you pull both the fuses, this prevents this from happening.
Old 03-21-2013, 11:55 PM   #4
WankelsRevenge
Annoying.
Do you mean the EGI COMP. or the EGI INJ. fuse?
Old 03-22-2013, 01:08 AM   #5
Oops, yeah, that sounds better.
Sorry, I haven't run a stock ECU in ages.
Mines runs a Haltech E8 now.
Old 03-22-2013, 08:42 AM   #6
tweiss3
Mazda Lover
tweiss3's Avatar
The pedal to the floor trick only works on an S5, not an S4
Old 03-22-2013, 09:40 AM   #7
WankelsRevenge
Yeah.... about that. Turns out Im an idiot and unplugged my puel pump while removing the carpet from my hatch and didn't plug it back in. Luckily I noticed it this morning while transferring my tools to my other car though. Plugged it back in and it started right up. The good news is this has motivated me to get some new injectors so I wont have to worry about this problem anymore.
Old 03-22-2013, 11:16 AM   #8
vrracing
Rotating Assembly
Before you go and spend the few hundred dollars for new injectors, you should make sure that's the root cause. You could have low compression as well.
Also note you can have your injectors cleaned for around $17 each which includes return shipping. I used KGParts (the fuel injector part of the company is called http://injector-rehab.com/shop/home.php) and they turned them around very quickly. You might be able to find someone locally to clean them so you only have to take a day off unless they are open when you are off.
Old 03-22-2013, 08:47 PM   #9
WankelsRevenge
Well the engine is a fresh rebuild and actually runs/idles/pulls great. The guy I bought it from told me about the flooding issue when I got it and after having the car a month or so Im fairly certain its a leaky injector. Probably just going to get a set of rebuilt ones for the time being until I start putting in some serious mods and need bigger ones.
Old 03-23-2013, 07:43 PM   #10
Tougemonster
Meat Popsicle
Tougemonster's Avatar
Tougemonster is on a distinguished road
Before I got my injectors rebuilt I use to unplug my fuel pump.
The connector is kinda by the drivers speaker tower, by the pump
Just unplug it, then turn over till it starts then run like a mofo an try to plug it in before it dies again. hah
So glad it doesnt flood anymore. But Ive pretty much replaced everything, so im not sure what fixed it unfortunately
Tougemonster is offline   Reply With Quote
Old 03-27-2013, 09:50 AM   #11
Shainiac
Shainiac's Avatar
Shainiac is on a distinguished road
It takes about 15 minutes to splice in a switch to the trigger wire on the fuel pump relay. It's right under the steering column. Iirc, I used a writeup on rotary resurrection's site. Easy and worked great. I'd turn off the pump right before I'd turn o ff the car and it would use some of the fuel in the rails and it'd be less likely to food the next time around.
Shainiac is offline   Reply With Quote
Old 03-27-2013, 10:05 AM   #12
reddozen
Gold Wheels FTW
reddozen's Avatar
I would imagine that a similar solution to the problem from the RX8 could fix this as well... Faster starter and upgraded ignition coils. I remember that my FC was plagued with fouling out plugs etc, but it wasn't tuned correctly, so it ran pig rich.
My Cars:
1974 RX4 Coupe
1991 FC3S RX7 - Sold
Old 03-30-2013, 09:20 PM   #13
Rotary Evolution
rotaryevolution.net
Rotary Evolution's Avatar
i'm curious where this revised starter for the early generations can be located..
Old 03-31-2013, 08:44 AM   #14
JL1RX7
Have to get the 2K rated starter. Most parts places sell both. So get the one with the higher output.
Old 03-31-2013, 11:06 AM   #15
vrracing
Rotating Assembly
You really mean "2 kw" as an 2 kilowatt, right? That's the A/T starter. It's compatible with the M/T cars?
