Old 03-16-2013, 11:24 PM   #1
mystery
mystery is on a distinguished road
85 rx7 carb upgrade
Ive been told by numerous people in my area that I can save myself some headache swapping the carb out in my 85 rx7 and found one with the right specs but now I cant find an adapter plate to make it fit. Guy I spoke with told me he cant get em but this is a link to the carb I was lookn to swap.. guy thought I was nuts wantn to put a 600 cfm carb on a 1.1 ltr motor. http://www.jegs.com/i/Holley/510/0-1...ductId=1434023 my question is does anyone know where I can get this adapter plate??
mystery is offline   Reply With Quote
Old 03-17-2013, 07:11 PM   #2
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
Maybe try one of these? Not sure how it works with your budget.
http://www.racingbeat.com/RX7-1975-1...nts/16464.html
Tuning a 600 to work on a stock port 12A might be a challenge. Not sure what your setup
might be so can't really say if it will work easily.
Old 03-17-2013, 10:08 PM   #3
mystery
Thats exactially what I was looking for but theres not just an adapter plate that can be mounted or does thw whole manifold have to be swapped?
Old 03-18-2013, 12:22 AM   #4
FC Zach
FC Zach's Avatar
Ive never seen such a thing for the Holley, there is an adapter that replace the upper assembly http://www.racingbeat.com/RX7-1975-1...ake/18100.html but these are for Dellorto/ Weber
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 03-18-2013, 06:02 PM   #5
diabolical1
I have radioactive semen
most I can say is that they existed at one point in time. I don't know about now and I can't recall who made/sold them, but they did exist. I had 2 friends back in the day with adapter plates to use Holleys on the stock 12A manifold, and I saw a handful of others on cars that I was less intimate with.
Old 03-19-2013, 06:55 PM   #6
mystery
So only way for the holly to fit is by swapping out the entire manifold correct?
Old 03-20-2013, 11:39 AM   #7
one320fc
one Apex @ a time
one320fc's Avatar
As far as I know theses days you have to change out the manifold. Weber carbs are a great upgrade over stock but can be pretty expensive. You can find used Holley setups on the forums pretty cheap I picked up my intake for 120 bucks and spent 300 on a 465cfm carb from summit racing. My buddy had luck tunning a 600cfm on a stock port 12A also!
1983 Limited Edition SOLD
1977 Mazda REPU I will work on it one day I sware!!
1987 T2 um after the repu is done??
2013 Chrysler 200 DD
2009 Dodge Journey
94 Volvo 850 N/A The slowest car I have EVER owned!!!
Old 03-20-2013, 04:28 PM   #8
As long as the 600 is vac secondaries you can get it to work. Performance is minimal over the 400-450s though and I would shoot for the smaller carb if possible.
You will have to modify the throttle linkage and probably some slight grininding on the lower ear of the holley manifolds (older racing beat manifolds didn't fit perfectly and thats usually what you find for sale when buying used). All in all its not a big deal.
If this is a daily driver, I would NOT run the 600. If you can locate a weber or mikuni 40, I'd run one of those instead.
Old 03-20-2013, 07:48 PM   #9
diabolical1
as a matter of fact, given your current situation, I would avoid it for now even if the car is not your daily driver. as mentioned before, it can be made to work, but you're skating uphill if you go this route, and if you think "making the Holley work" is going to be easier than just troubleshooting (or possibly) replacing the Nikki, then, oh boy, do you have another thing coming. not to mention you will probably cut your level of support on the boards by a good 60%, and of course, there is no FSM reference for it either.
I probably should have posted this in the other thread, but either way, i'd be telling you the same thing. if you want a Holley that's fine, but I think you need to get some basic troubleshooting and tuning skills under your belt first and it's much easier, and better to start with the Nikki.
Old 03-22-2013, 09:48 AM   #10
mystery
Well problem im having is the guy before me had swapped out the carb that origiginally come on it with a used one he found somewhere. As well as redone alor of vaccuum lines that I cant find a diagram to how his setup of. The hood I have on the car has a diagram but it doesnt matchup to anything he has. Only thing thats the same is the hoses coming off the top of the row of relays.. theres no fuel in the carb bowls so im lost as where to start next. If it comes to me having to get another carb from what I hear edelbrock more or less will come tuned with minor adjustments holleys dont. Might be to the point I need to have it towed to a shop??
Old 03-22-2013, 02:23 PM   #11
one320fc
one Apex @ a time
one320fc's Avatar
People might disagree with me on this one but if you don't have emissions where you live find the how to section and remove the crap and slap on a aftermarket carb! I just think you will invest way to much time tracking down crap that someone else has already screwed with! my 465cfm Holley pretty much fired right up out of the box..of course it did need to be tuned but will start and run. The archives and how to section will save you lots of headache! You can even find the factory service manual (FSM) for your 85..
2009 Dodge Journey
Old 03-22-2013, 08:10 PM   #12
mystery
Actually was able to talk to a mechanic today that used to own one and gave me some more than useful advise and offered to come take a look so that being said I should have an answer soon! And carb will get upgraded eventually my concern is just knowing it will run and stay running!
Old 03-31-2013, 08:37 PM   #13
mystery
With lots of trouble shooting and tinking I dismantled my old carb and was able to find 2 more bolt filters after that I pulled them off my one in the car and found they where broken apart and clogging the primary jets from getting fuel... now that ive cleaned the gas tank its either going to get rebuilt or replaced. Been looking into the 48 ida weber with the new manifold as well. Anyone have any experience with them or know what else would need to be swapped after that?
