Old 03-11-2013, 09:18 PM   #1
Vacuum Block Issues/Routing
I have a vacuum block I'm making out of brass fittings. Currently I have my boost gauge (1/8" nylon line), GM MAP sensor (3/16"x12" [needs to be 1/4"]), and FPR (5/32") run off of a single line (5/32") from the manifold. I'm concerned that there's going to be a pressure drop or something from feeding so many things from one 5/32" line.
Is this going to cause any issues?
Old 04-01-2013, 08:00 AM   #2
88turboii
destroy, rebuild, repeat
88turboii's Avatar
i would run the FPR off the nipple on the inside of the LIM. the gauge and sensor should be fine split from one source
Old 04-01-2013, 09:50 AM   #3
It should be fine.
The only one important vacuum line you need to worry about is for the BOV for a turbo engine.
I don't think you need to worry about this in your case.
Old 04-01-2013, 02:25 PM   #4
K, good to know. I'm actually currently running without a BOV (very limited) because mine busted... stupid Ebay crap.
