Go Back   Rotary Car Club > Classifieds > 3rd Gen Classified > 3rd Gen RX-7 Interior Parts
3rd Gen RX-7 Interior Parts Anything to do with interior... seats, carpet, door panels, etc.
Old 02-03-2013, 11:26 AM   #1
bmorerotors
bmorerotors is on a distinguished road
wtb stock bose items.
stock bose cd player, and a stock driver side bose speaker amp. or i need tech advise to fix mine. the speaker is just squeeling, so i know its getting some sort of signal. and the cd player turns on, but wont recongnize any disks, then spits them back out at me. any help would be appreciated.
bmorerotors is offline   Reply With Quote
Old 02-03-2013, 10:58 PM   #2
Skatelement
Senior Member
Skatelement's Avatar
Skatelement is on a distinguished road
Bose Audio
I had issues with the bose amp speaker enclosure as well. Most fixes are replaceing the electrolytic capacitors in the amp module inside the enclosure. when going out they do all sorts of squealing poping etc... If you can solder just replace all the caps with same values or have someone replace them. Fixed 90% of the bose problems As far as Audio sound issues.
Skatelement is offline   Reply With Quote
Old 02-03-2013, 11:08 PM   #3
Skatelement
Senior Member
Bose CD player Deck
Most likely the CD pickup Assembly is out in your system this is common with cd players. once in A while I will find A bad spindle motor but rare. Some models you can look at the pickup assembly and match it up online electronic suppliers such as mcm and even ebay has some pickups for may cd applications. most new pickups when you receave them have the lazer diode shunted to ground to protect them in shipping. requires you to remove A ball of solder before operation. should be noted in your new assembly if not ask the supplier about this as it will save alot of stress as to why the new pickup dosen't function. ben down that road. As far as the spindle you can usualy tell if the disk atempts to spin. which mostly clears up the question of the spindle motor.
Old 02-11-2013, 08:38 PM   #4
bmorerotors
thanks a lot for the information. hopefully i can get some of this to work soon. Having the car so close to mint and not being able to have it done is frustrating.
Old 05-04-2020, 08:39 PM   #5
RE_guru
RE_guru's Avatar
RE_guru is on a distinguished road
I have factory Bose Head units. They worked when I pulled them out of the car in 04 and put them in storage. PM if you are interested.
'94 Mazda Rx-7 montego blue
'88 Mazda Rx-7 se (SOLD)
'04 Mazda Rx-8 GT 6spd (daily)
Control Freaks www.cfdrift.com
All Your apex R belongs to US!
RE_guru is offline   Reply With Quote
